Old 01-15-2009, 10:20 PM   #1
Blueabyss
Default Connectors
I am building a 500 ESP and was wondering if it would be ok to use the E-Flight Blue Battery connectors. Will they carry enough power/amps. I know deans probably will cary more amps but i cant stand how hard they are to disconnect...
Chris
Blueabyss is offline        Reply With Quote
Old 01-15-2009, 10:30 PM   #2
netwalkr101
Try some Dielectric Grease first. I have been using it for a while and works great! You can get it just about anywhere automotive parts are sold. You will have to reapply for time to time but makes the connectors SOOOO much easier to get off.
netwalkr101 is offline        Reply With Quote
Old 01-16-2009, 02:27 AM   #3
sell500trex
I use these deans connectors and have no problems connecting / diconnecting. Highly recommended.
http://cgi.ebay.co.uk/BEST-Deans-typ...1%7C240%3A1318
Steve
Blade CX2, Trex 500 CF, Scale project : Vario airwolf turbine- started March '09
sell500trex is offline        Reply With Quote
Old 01-16-2009, 04:36 AM   #4
lavi
Steve
+1
I buy this connectors from hobbycity.
the picture on hobbycity site does not show the ribbing on the sides, but its the same as in the picture.
lavi is offline        Reply With Quote
Old 01-16-2009, 04:40 AM   #5
xptical
I like my connectors to fit really tight. Gives me a sense of security.
She felt like someone of an ambiguous age that even neilg would approve of...
xptical is offline        Reply With Quote
Old 01-16-2009, 08:16 AM   #6
geoavia
+1 on lavi-s post.
I bought 10 pairs of those from hobbycty, very nice quality. recommend!
George
Helis: TRex 450S all metal, TRex 500CF
Planks: EZ Star FPV mod, PA Katana mini
geoavia is offline        Reply With Quote
Old 01-16-2009, 10:19 AM   #7
EVBmcx
I use power poles - they are easy to connect and secure.
Ed
Always Something New!
T-Rex 500ESP, GY401/9257, 6s 3000mAh 100% Flat TC X9303; Blade mCX
EVBmcx is offline        Reply With Quote
Old 01-16-2009, 11:22 AM   #8
srhadden
Deans are OK. I color one side black with a permanent marker. You also have to be careful when soldering to not push the female connectors out. due to the heat on them. One time I did this and because they were pushed out too far I shorted my battery when I fumbled to plug it in.
T-REX 600 SNP: Stock Blades, OS 55HZ Hyper, Hyper Pipe, 9254 Cyclic , BLS251 w/ Spartan 760, Align 2-1, MultiGov w/Spektrum RPM backplate sensor
srhadden is offline        Reply With Quote
Old 01-17-2009, 04:24 AM   #9
Leaf Blower
Chris
Yes, they will.. Plus the safety advantage that neither male nor female connector has exposed metal surfaces.
In order of acquisition: Lama V4,Walkera 60B (RIP), HBK2, Blade 400 3D, T-Rex 450SEV2, T-Rex 600E, T-Rex 600NSP, T-Rex 500..
Leaf Blower is offline        Reply With Quote
Old 01-17-2009, 07:10 PM   #10
Z900
Don't like (HC)deans.... I'd several times bad contacts.
For me is the best (in your case): 4mm connectors (for the best electrical contact and easy to pop off)
Z
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500
Z900 is offline        Reply With Quote
