| 2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
I almost sold my DX7 to pick up a new SE model. Thank god I looked at all the specs because it doesn't have the trainer port in the back so it will not work with my Phoenix sim. Why would Spektrum would make a radio that won't work with a sim?
Wow, makes me happy to have my plain 'ol DX-7, as I use the trainer function to buddy box new airplane pilots. Doesn't make sense why Spektrum would do away with it.
Warp 360 Spartan Vortex VX1 |
AFAIK it is because of some incompatibility when running the 11ms frame rate. SO best to not have it active.
Terry AMA#47402, IRCHA # 3395 Blade CP "Pro", Trex 450SE, PiccoZ, Quick of Japan EP8v2 EX, Hurricane 550, Hurricane 200, JR Vibe 50, Blade mCX, Bergen Intrepid Gasser, Pantera 50, Blade mSR, Novus CP |
you get what you paid man, should have keep your old dx7 for back up and sim.
i just got a dx7 SE myself , and still keep my old dx7 for back up
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
is there any new feature on the SE version software?
Gaui X7 Gaui X5 |
#6 |
Its faster and 2048 resolution
Andy AMA 77227 Jacksonville FL To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
its only faster if you use certain receivers like ar7100 and up it is the same dx7 with ar7000 6200 and 6100
#8 |
That's not entirely true. The DX7se always outputs an 11 mSec frame rate. So even with the DSM2 1024-step resolution receivers (i.e. AR7000, AR6200, etc) - you'll get a decrease in latency. However, the 1024-step resolution receivers have a slower processor than the 2048-step receivers, so the reduction in latency will not be as much.
#9 | |
Are you sure?
#10 |
I am sure ...
Besides, if it switched back to the 22 mSec frame rate - you'd be able to use it with your sim |
#11 |
it would be much better if they just do something about the software like addeding delay between the flymodes.
Gaui X7 Gaui X5 |
#12 | |
And anyway, you can't do a 11 ms PPM output, so the reason for the lack of trainer port is that the processor internally is running faster than PPM can, so no PPM signal, so no signal to output to the trainer port. As per my quote from the Spektrum site, the Advanced features are ONLY available with certain Rxes.
#13 |
Pine - I realize that you cannot produce PPM output at 11 mSec, and I did not imply that you could. What I said proposes that if the DX7se had the ability to select frame rates (which it currently does not), then you'd be able to enable the trainer port when outputting frames at 22 mSec periods.
However, my original statement is indeed fact - the DX7se DOES output its frames at 11 mSec when transmitting to 1024-step resolution receivers. The total latency is a function of the transmitter's frame rate and the receiver's processing speed (as well as other factors). |
