Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 01-18-2009, 02:00 PM   #1
mxrider2637
Default Blade cp pro 2-yeh or neh?
i was looking at the walkera 4g3 to get and came across the blade cp pro 2 and was thinking about getting it instead because if (sorry "when") i break it i would have a easy way of getting parts and also the shipping on the 4g3 was 53-80 dollars. Outragous!!. anyway, is the blade cp pro 2 easly flown in gymnasuims and would it be about the same difficulty of flyin compared to the 4g3 since they are both collective pitch>
mxrider2637 is offline        Reply With Quote
Old 01-18-2009, 03:53 PM   #2
The Steve-O
My blade cp is perfect for the gym. You won't have an issue with room (unless you drift a lot into walls). I don't have any other small cp heli's to compare its stability with though.
Blade Cp, T-Rex 450 Se V2.75 (mikado head, beam swash and tail, 7200BX), Airwolf 450sa, Blade mCx, mCPx, mSR, Cx2, Swift, Havoc Heli
The Steve-O is offline        Reply With Quote
Old 01-18-2009, 04:05 PM   #3
mxrider2637
If u compare flyin a cp to a blade cx, are they alot harder? I am pretty patient
Old 01-18-2009, 04:28 PM   #4
ccieslin
Blade cp and cx2 are soooooooooooo different it's not even comparable. I'd say go with the cp2 but god only knows when it'll be released...........it has been pushed back so many times at this point it's no longer funny. My guess is something is wrong with the cp2 or would have been released last summer as scheduled. I can tell you from experiance that the blade cp pro is one frustrating bird.
T-REX 600 LE OS55hz+powerboost, savox sc-1258tg cyclic, ReactorX2 regulator, CGY750 Flybarless!
T-REX 450 Pro Beastx
Futaba 8FG
ccieslin is offline        Reply With Quote
Old 01-19-2009, 12:51 AM   #5
helidude3
I must be the only one saying this, but the blade cp pro is my favorite heli. I have a blade 400, but the tail does not work right. With the DD tail mod on my cp, it holds even better than my 400.
mxrider2637: IF you are REALLY REALLY PATIENT, then you would be good with the cp. I am a kid and I do not have a lot of money so I was not able to go out and buy a t-rex 600 when my cp broke. This is what has helped me get into helis. The cp is easy enough to fix for a beginner. Just remember, if you want to get good at helis, fix them, don't buy a new one.
helidude3 is offline        Reply With Quote
