Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters
E-Sky Helicopters E-Sky Line - Help each other out!!
Old 01-18-2009, 03:05 PM   #1
BOBBERJOHN
Angry OMG! WHAT DID I DO?
Just got a new ESKY HFP MK3. While hooking up LIPO batt to mixer, I pluged the 3 hole white connector from the battery into the 3 pin hole marked "battery" on mixer!! This connector is supposed to plug into the charger! WHAT AN IDIOT!! After I saw my mistake, I removed the white connector & plugged in the correct 2 pin connector. Now the LED flashes red & green non-stop & the servo arms start moving uncontrollaby. Servos won't respond to TX. HELP!!!!!
BOBBERJOHN is offline        Reply With Quote
Old 01-19-2009, 11:25 PM   #2
mnwizard
Are you turning on your Tx before you connect the battery?
- Jack
Cranky old fart and charter member of ESO
Lots of Helis
mnwizard is offline        Reply With Quote
Old 01-20-2009, 10:37 AM   #3
BOBBERJOHN
YES!
Old 01-20-2009, 12:44 PM   #4
DumbDawg
Ouch.... You could try the standard guy fix by blowing on it and tapping it... this is the universal fix for everything.... not funny but I'm think'n if you are now turning the Tx on first, then the heli, and its acting as if you are plugging in the heli and not turning on the Tx first... I'd say you may have cooked the mixer... especially if it won't respond to Tx inputs...
Al I can say is try starting all over... place all tabs to center, throttle tab to zero.. center the control stick and zero the throttle stick... turn on the Tx, then plug in the heli and wait a minute to see if the mixer initializes... If this don't work... buy a new mixer...
Expensive lesson but one that likely won't be repeated anytime soon....:o sorry it happened
happy heli'n
DumbDawg is offline        Reply With Quote
Old 01-20-2009, 10:02 PM   #5
BOBBERJOHN
Thanks. I ordered a new mixer today. Hope it does the trick.
Old 01-26-2009, 09:40 AM   #6
Jonnyheli
Any luck with the new mixer?
-Jonny
Spektrum DX7, Align Trex 250se, Align Trex 500cf, Align Trex 600n LE
Jonnyheli is offline        Reply With Quote
Old 02-02-2009, 01:14 PM   #7
Heli Yea!
If that doesn't work you have fried the crystal. My Belt CP acted the same way when I fried my crystal. I just hope you didn't buy a mixer if all you needed was a crystal set.
-Heli Yea!
Master of: the living room, stockTx, mechanical setup and, the obvious!
Belt'ish CP MG90's,704A/S3114,CX head,HDX3550/Align 35G/HDX 500 SAH:-) HS-82MG's,G401B/BMS-631MG,HDX850/Align 60G,6s lipo /Hirobo Shuttle ZX .30 /Walkera 4#3B/Falcon40/Lama V3 DX6iThank you kind gents! :-)
Heli Yea! is offline        Reply With Quote
