Go Back   HeliFreak > R/C Airplanes Info and Support > Foamies and Park Flyers
Foamies and Park Flyers 3D Foamies and Park Flyers are an EXCELLENT way to improve your reflexes and stick finesse
Old 01-19-2009, 11:16 AM   #1
Navigator53
Default Why does each Plane or Helo run on a different battery voltage?
Just getting started on planes and was hoping to use some of the batteries I already have plenty of.
Blade CX2 = 7.4 volts
Blade CP = 9.6 volts
Trex 450 = 11.1 volts
Will probably get the Firebird Freedom as anything that takes 11.1 volts (T-28 Trojan) will probable get destroyed in the first 10 minutes
Of course the Freedom Flyer needs 8.4 volts
http://www.hobbytown.com/Products/RC...ProdID=HBZ7000
What would happen if I ran 9.6 or even 11.1 in it?
Smoke the ESC, the motor or can we fudge a little?
Thanks guys
Mel
Navigator53 is offline        Reply With Quote
Old 01-19-2009, 06:15 PM   #2
Pinecone
Blade CP will run on 11.1 volts.
7.2 volts = 6 cell NiCd or NiMN
7.4 volts = 2 cell lipo
8.4 volts = 7 cell NiCd or NiMH
9.6 volts = 8 cell NiCd or NiMH
11.1 volts = 3 cell lipo
14.8 volts = 4 cell lipo
Most anything that runs on 9.6 will run on 11.1. At wosrt you might need the next size smaller prop.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote
Old 01-20-2009, 09:49 PM   #3
Navigator53
Thanks Pinecone,
I bought the AeroBird Swift, it's 8.4 volts says it can also use 9.6 which my Blade CP also uses.
Maybe I'll try 11.1 ....
I learn a lot from your posts, thank you
Mel
Old 01-21-2009, 09:17 AM   #4
Pinecone
8.4 to 11.1 is a BIG jump and may burn out the motor.
Also, you have to watch the max voltage rating of the ESC.
Terry
Old 01-21-2009, 02:02 PM   #5
Navigator53
OK, you talked me out of it
Old 01-24-2009, 09:20 PM   #6
joegamma1
And if it's nihm that is factory wouldn't using a lipo be unsafe due to the dif in low voltage cut-off?
Oh yea that'll work, go ahead
joegamma1 is offline        Reply With Quote
Old 01-25-2009, 01:37 PM   #7
Pinecone
You would have to fly by timer.
Terry
