Go Back   HeliFreak > R/C Helicopters > Contest Flying
Contest Flying Contest Flying F3C/AMA
Old 05-16-2006, 02:00 PM   #1
Gary O
Default Set Up for dedicated Tempest FAI Contest Model
Gordie,
I'm really interested in contest flying, but would like to start with a model that is set up strictly for it. Can you give me a set up for a Tempest FAI that would be just for that. I have other helis for 3D so I don't have to worry about trying to make one do both. Thanks for your help.
Gary Owens
Who says obsession is a bad thing
Gary O is offline        Reply With Quote
Old 05-16-2006, 02:07 PM   #2
DavidH
I use the Tempest FAI head, Setup to Cliff's Hiatt's instructions. With one exception I use the 60 duro dampeners all the way.
I use the Pro III paddles at 45 grams.
Using 710 mm TG blades at 200 grams
1475-1500 rpm in hover mode.
Using about 3 degs of cyclic deflection in hover mode.
Aerobatic mode,
Turning 1900-1950 rpm on the rotor head,
7 - 7.5 degs of cyclic defection
pitch curve -7 to +10
Autorotation
pitch curve -7 to +13
David
DavidH is offline        Reply With Quote
Old 05-16-2006, 02:13 PM   #3
Gary O
David,
Thanks, I'll try that. The Pro III paddles you mentioned, are they an MA item or someone else? Also, where would I find the Cliff Hiatt instructions you mentioned.
Gary
Old 05-16-2006, 02:19 PM   #4
DavidH
Cliff's Recommendations for the FAI head setup are in the instruction manual for the Tempest FAI.
The paddles I am referring are the ones that come with the Tempest FAI rotorhead.
David
Old 05-16-2006, 08:56 PM   #5
GM1
I don't run quite as much cyclic as David. I run 2 1/2 degrees in normal and 5 degrees in idleup. Cliff's head set up is very good and an excellent place to start. After flying it for a while you may want to slightly change the delta but I would wait until I was VERY familiar with the feel of the whole system.
Gordie
In a dog sled team, if you're not the lead dog, the view never changes.
GM1 is offline        Reply With Quote
Old 07-25-2006, 08:46 AM   #6
tnreefguy
How do you change the rate of your cyclic deflection in different flight modes. I dont think my 9chp is capable of that.
tnreefguy is offline        Reply With Quote
Old 07-25-2006, 08:58 AM   #7
DavidH
You use Dual rates and a switch. Put elevator and aileron dual rate on the same switch.
David
Old 07-25-2006, 12:21 PM   #8
tnreefguy
OH. Thanks David.
