Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Duralite
Duralite Duralite Battery Li-Ion Li-Mn Chargers Support Forum
Old 06-01-2004, 07:34 PM   #1
Kinger
Default Question Regarding Duralite Charger
Hey guys,
Lately I've been thinking of switching over to the Duralite system for my two Evo's. (2800 flat packs) My question concerns the use of the 1RX 7.4 Volt DC charger. Can this charger be hooked up to a power supply without any problems (I've got a Hobbico 12V supply that I'm using with my current charger.) or do I need to purchase the wall adapter?
Anyone using the 2800 packs with analog servos? Just curious as to how many flights I might get if my Evo's have 9202's all the way around other than the 9253 on the tail.
Thanks,
Mike
Team Synergy
Kinger is offline        Reply With Quote
Old 06-01-2004, 07:46 PM   #2
pepper
I was running 4 9252's , 601, tj pro. and some mild aerobatics and a 4000 pack lasted me i think about 4 days before i just decided to change them, it still load tested just over 6.1,
not really sure about the 2800 packs, but i will for sure be staying with duralites!!.
as far as the charger, to be just plain safe, i have the wall charger..
pepper
GOD BLESS
ONE DAY YOU ARE NICE, JUST MAY CHANGE SOMEONE'S LIFE!!!!
pepper is offline        Reply With Quote
Old 06-01-2004, 07:49 PM   #3
WillJames
Registered User
Shannon gets about 10 flights on his Ion with a 2800 pack. :glasses2:
William James
WillJames is offline        Reply With Quote
Old 06-01-2004, 08:04 PM   #4
DavidH
Mike,
You can use a power supply to power the Duralite charger. The charger will operate off 12 volts from a battery or from the wall adapter. A power supply that is putting out 13 volts will handle the job.
David
DavidH is offline        Reply With Quote
Old 06-01-2004, 10:17 PM   #5
Kinger
Thanks guys.
David- The Hobbico is rated to give an output of 12V. Will that not cut it?
Team Synergy
Old 06-05-2004, 05:40 AM   #6
BigVanVader
that should work fine Kinger....i use a power supply from a computer to power my duralite charger.....no problems
Vance Hill
BigVanVader is offline        Reply With Quote
Old 06-05-2004, 06:15 AM   #7
Kinger
Thanks for all of the comments guys. Ended up buying two 2800 flat packs, 2 5.1 regs w/failsafe switches, the wall unit and the 1 RX output charger this week. Decided I would just part ways with my charger, PS and old packs once the new stuff arrives to help offset the cost.
Looking forward to the new Duralites arriving next week!
Team Synergy
Old 06-07-2004, 07:48 AM   #8
Fredrik aka. mrNoodles
Hey Kinger!
First you have the same worn issues on your EVO as on mine Sceadu, then you go ahead and order 2 packs and 2 5.1V regs w/switches as I just did. :cool:
(I ended up with 2x4000mA, 4 output charger)
You must be one of my missing twinbrothers :wink:
TeamHirobo Sweden
Fredrik aka. mrNoodles is offline        Reply With Quote
Old 06-07-2004, 11:26 AM   #9
Kinger
LOL.........you are cracking me up Fredrik Make sure you post some pictures of how you got your 4000mah packs in your Evo. (If that's in fact where you are putting them.)
Funny you mention the wear problem on the Evo. Just noticed yesterday that I think I have a cracked autohub bearing on mine. When I gave the heli 1/4 throttle on the ground the engine reved up but the rotors didn't turn. Then all of a sudden it engaged at about a little less than 1/2 throttle. Trying to determine if it's a worn clutch liner or my bearing.
Team Synergy
Old 06-08-2004, 03:40 AM   #10
Hey Kinger!
Just recieved my Duralites, tremendous fast service (Jack is the man!), shipped on Thursday/Friday.
Will post pics of them, one for my Freya and one for the Sceadu.
PS. I cracked/replaced my onewaybearing earlier this Spring - 'brother'! :wink:
TeamHirobo Sweden
