Old 01-25-2009, 09:02 PM   #1
cobra25
Default servo arm 90" how far linkage from center servo screw in mm
cobra25 is offline        Reply With Quote
Old 01-25-2009, 09:05 PM   #2
airjawed
What gyro and servo?
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V
airjawed is offline        Reply With Quote
Old 01-25-2009, 09:09 PM   #3
pwoodyp
Assuming the front three ---> but not the tail servo -->
Then ---> I could tell ya but I'd have to kill ya ---> If HS-65MG then ---> here's a clue.
pwoodyp is offline        Reply With Quote
Old 01-25-2009, 09:19 PM   #4
GreenCello
13mm for cyclics, variable for tail servo
GreenCello is offline        Reply With Quote
Old 01-25-2009, 09:23 PM   #5
cobra25
ok swashplate servos arms 90 linkage 12mm or 13 or it only matters until linkage arms are at 90 and they are hitec 65
Old 01-25-2009, 09:24 PM   #6
cobra25
i tryied 13mm and the linkage was not straight is 12mm ok then
Old 01-25-2009, 09:27 PM   #7
R0t0R
Basically it's whatever it takes to get the linkages vertical to the swash.
R0t0R is offline        Reply With Quote
Old 01-25-2009, 09:32 PM   #8
pwoodyp
Yup pretty much what he said.... my first hole is 10mm (or is it 11mm, my eyes I tell ya) and the second hole 13mm... to equal spot on 90 I would have to drill a new hole....
Old 01-25-2009, 09:37 PM   #9
cobra25
all of you great help thanks
