Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 01-31-2009, 05:00 AM   #1
Bitswap
Default 700N Main Saft Doesn't Fit Bearing Blocks
Greetings,
I'm building a T-REX 700N and got to the part to check the left and right frame alignment. The main shaft to the rotor will not go through either of the bushings or bearing blocks in the frame. I have cleaned the parts and oiled lightly, but the main saft will not go through even the top one. I've built the head already and yes, there is only one hole at the bottom of the main saft I'm trying to insert.
I've lightly sanded the shaft with 600 grit sandpaper to no avail.
Am I missing something here or do I need to call Align?
Thanks in advance,
Bit
Edit: The swashpate and parts above it fit perfectly.
Bitswap is offline        Reply With Quote
Old 01-31-2009, 06:10 AM   #2
heliadict1212
looks like align has the monkey back in QC again! If you cant get it through EITHER bearing blok at all then looks like youll need some new stuff. Aligns tolerances in their shafts SUCK, which is why it is so easy to kill the bearings in the 600.
heliadict1212 is online now        Reply With Quote
Old 01-31-2009, 06:19 AM   #3
Danal Estes
Yes, call align for warranty parts. Meanwhile, order a couple of shafts from somewhere to get in the air.
Trex 700E - SuziHans,V-Bar,JR8717/BLS251,X-Era 4030/3Y-460,12S Rhino 4900; SH frames are ~1 Lb lighter than Align 700E kit
Trex 700N - 7100R/JR8717@8V/GY611
About a dozen more, including 2xTrex 500 - 1 V-Stabi/6S, 1 Flybar/5S,GY770/DS3400G
Danal Estes is offline        Reply With Quote
Old 01-31-2009, 07:00 AM   #4
Bitswap
Thanks for the replies.
I'll call Align. In the meantime, I just put the shaft on my lathe and turned it down a bit.... moving forward.
Old 01-31-2009, 10:09 AM   #5
Azlum
This happened to alot of people during the build.
I chucked my mainshaft into my drill and sanded it with 600grit for about 5 seconds at a time until it fit perfectly.
[ SAB Goblin ][ Trex 450 Pro ]
Azlum is offline        Reply With Quote
Old 02-01-2009, 02:36 PM   #6
mapleleafs
same here....
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline        Reply With Quote
