What head speed can I except see running a 14 tooth pinon at 100% throttle using a scorpin 90 amp controller?
3g 550 Trex and 700le flybarless |
download a headspeed calculator.....
MSR/Trex250/3-Hoss X4E/Flasher 450/BlackHawk500SePro/Trex500CF/HossX5R/Hurri550 Scale Jet Ranger/Trex600E/Dx7! |
about 2400rpm....
Z
| mCPX BL@DX6i | Trex700N-LE@BX | TDR@BX || FunJet 2W20@4S | SwiffieII || FF10 || 720i DUO3 | ALC8500 |
If you are talking about the Scorpion 3026 1400kV motor, then with a 14t pinion it would be in the 2400rpm range, but with this motor you should run a 15t pinion (2550rpm HS) and hang on as this is a ballistic combo on the 500...........
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC Hyperion 1420, Mega Power Gemini Chargers! JR XG11 Old hand at Planks To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I just bought that motor with the 15 tooth pinion. I look forward to my first test flight.
