Old 02-03-2009, 04:17 PM   #1
Druznm
Default Pulled the trigger today picked up the 250
I have yet to master more then a tail in hover but decided to pick up the 250 its just too cute, But I am not going to fly it until I master flying my blade 400 this baby is sweet though, I will start assy tonight I think.
Anyone have tips/tricks/thoughts ideas on the assembly?
Druznm is offline        Reply With Quote
Old 02-03-2009, 04:24 PM   #2
HeathH
be very gentle with the screws. other than that it is a really easy build. it is one of my favorite helis now.
HeathH is offline        Reply With Quote
Old 02-03-2009, 04:26 PM   #3
Druznm
ha just as I read "when tightening linkage balls and screws please note to tighten them firml , but do not over tighten or the plastic parts will break or you will strip your screws..
Oh well time to just take it nice and slowly.
Does there happen to be any assy videos like Sokul has ?
Old 02-03-2009, 04:34 PM   #4
HeathH
yes jasmine did the build vids for it.
Old 02-03-2009, 04:59 PM   #5
Azlum
Dont even TRY to tighten/loosen any of the balls on the metal head parts. You WILL snap one off if you do.
[ SAB Goblin ][ Trex 450 Pro ]
Azlum is offline        Reply With Quote
Old 02-03-2009, 06:08 PM   #6
toyturbo
When you're inserting the align 0.9mm allen wrench tool into the screws, they sorta have to click into place before you start turning or else you will strip them, just be careful and wiggle it around until you hear a click, and that it is fully seated.
toyturbo is offline        Reply With Quote
Old 02-03-2009, 07:26 PM   #7
Druznm
Ran into my first problem.
On the Servo's in the manual it shows 4 holes on the ------()------ servo arm. The Servo arm s that came with the model have 5 holes --------------()--------------
What do I do, put them on the 4th hole or the 5th hole?
If I leave them where they are on the 4th hole it "looks" like after attaching the linkage they would hit the servo itself, may have answerd my own question but still need to double check?!
Old 02-03-2009, 08:05 PM   #8
Druznm
next hang up...
How far up or down or where do I tighten the lock collar on the main shaft?
Old 02-03-2009, 10:35 PM   #9
cbrian4
Use the last holes on all servos and the collar thing, attactch your main gear to the bottom of the shaft and pull up on the shaft firmly and slide the collar down as far as it will go so that its against the bearing at the top; tighten the collar when you are pulling this should preload it a bit and there should be no play. To check for play grab the head and try to pull up and push down on it. The shaft should not budge.
cbrian4 is offline        Reply With Quote
Old 02-03-2009, 10:39 PM   #10
Druznm
I am also noticeing a slight difference in where the motor gear meets the main gear , and where the main gear meets the tail rotor gear. The main gear is even with the motor gear but is slightly higher or lower *dont recall* , in relation to the tail rotor gear. I am curious if I didnt put the main motor gear on correctly, even though I followed the rules on glueing it flush with the motor shaft...
6 hours and about 70% done should have it done by tomorrow god willing this migraine goes away. Thank you everyone.
Old 02-03-2009, 10:42 PM   #11
HeathH
my tail gear is a little lower than the main i think. i have had no issues with it being that way on roughly 20 flights.
Old 02-04-2009, 04:11 PM   #12
Druznm
Thanks for the help, getting it ready to begin day two of assy, standbye for more questions... hopefully not but you never know
Old 02-04-2009, 04:22 PM   #13
HeathH
it is a really fun heli you will like it
Old 02-04-2009, 04:24 PM   #14
Druznm
As I sit here installing servos into spaces smaller then the crack of a fleas butt I am thinking how am I going to level the servo's horns after it is assy?
Should I plug in the radio while its in pieces and 90* all the servos before building 100%?
Old 02-04-2009, 04:31 PM   #15
helidude3
on jasmine's video she plugs it all in while she is setting everything up. I think it would be complicated to do it afterwards because of where the servos are positioned.
helidude3 is offline        Reply With Quote
Old 02-04-2009, 04:35 PM   #16
HeathH
i didnt watch her vids, but i installed the servos in the frame and then when setting up the swash mix i added the horns. you can reach the elevator output shaft after the servo is installed.
i also removed the top half of the frame from the lower when setting up that way i could reach the receiver easier.
Old 02-04-2009, 04:36 PM   #17
Druznm
Ok, thats what I figured, do I use the JR 7 channel config to setup? I am using a DX7
Old 02-04-2009, 04:38 PM   #18
HeathH
not sure what that is? choose the 3 servo 120deg swash in the dx7. i also didnt use the instruction manual either.
Old 02-04-2009, 04:40 PM   #19
helidude3
Its adifferent radio so set up will be different. I think that some would be the same ie. servo reversing.
