Old 02-09-2009, 10:00 PM   #1
Helihangover
Default Pitch help Please..
Hi all. Finally got a pitch guage today.. Doing some checking and the numbers didn't come out like i thought they should.. Need someones advice on what it should be.
This is with the stock throttle and pitch curves for the dx6i
Normal
Low- 5deg
1/4- 7deg
1/2- 9deg
3/4- 15deg
Full- off the guage.
Stunt
Low- -1
1/4- 5
1/2- 8
3/4- 14
Flybar level with boom. Haven"t never turned any ball links more than 1 turn before. This is how it came from the factory.
It starts to take off around 1/4 stick..Any suggestions or help would be appreciated..
Helihangover is offline        Reply With Quote
Old 02-09-2009, 10:05 PM   #2
sokal
Normal
Low- 5deg
1/4- 7deg
1/2- 9deg
3/4- 15deg
Stunt
Low- -1
1/4- 5
1/2- 8
3/4- 14
go thu my head vids
seems like your a bit off
will take some swash, washouts, flybarcage, and blades to get it right
also its best to set everything up in full range mode IE idleup/stunt
with a pitch curve of 0-25-50-75-100
i set my hold pitch curve up the same as idle up curve so i dont have to unplug motor
but be extreamly carefull doing so if u acedently turn hold off with throttle stick at mid stick it will start spinng very quickly so for now till you get more acuainted in the hobby unplug motor its the safest way to keep you fingers and other body parts
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote
Old 02-09-2009, 10:34 PM   #3
Helihangover
Default Pic enclosed
Yeah, I always unplug the motor when I am working on my bird.. This is a pic of the reading at full throttle idle up mode.
I didn't buy the wrong pitch gauge did I?.. It's the only one the LHS had. Am i doing the pitch gauge wrong maybe??
Old 02-09-2009, 10:36 PM   #4
sokal
looks like you need to either lower your swashmix pitc setting as long as full neg is the same
if not then you have some adj to do bro
Old 02-09-2009, 10:44 PM   #5
Larry227
It's also not unusual for them to come right out of the box that far off. I know mine was. I just considered it the first step in getting to know my Blade.
Larry227 is online now        Reply With Quote
Old 02-09-2009, 10:49 PM   #6
Slyster
WOW that's far off. It should be -10/0/+10.. yes view the vids! It's kindof fun setting up the head too
It's not just a hobby... it's a lifestyle!
Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo
Pete Team Outrage.
Slyster is online now        Reply With Quote
Old 02-09-2009, 11:01 PM   #7
1BADAIR
swash to low maybe???
any pics of the head/swash at mid stick?
TREX700LE-beastx,TREX 600LE-vbar,COMPASS 6HV-beastx,
1BADAIR is offline        Reply With Quote
Old 02-09-2009, 11:10 PM   #8
Helihangover
I will get some pics of the head tomorrow at midstick.. And try a few things sokal told me to try. i will post my finds tomorrow..
Old 02-09-2009, 11:19 PM   #9
1BADAIR
I wish the RTF manual was like the PNP manual. Lots of good info in it.
It says the swash should be 16.25mm from the chassis at mid stick
http://www.e-fliterc.com/ProdInfo/Fi...Manual_Web.pdf
Old 02-09-2009, 11:37 PM   #10
mr2mkii
I was thinking the same thing. Mine came with the swash a bit too high from the factory, but it was still setup pretty close for 0 pitch and range. Only recently did I lower it back down to were it really should be.
Blade mCX / mCPx / 130X / B400 HS-65MGs FBL CopterX w/3400g CCBEC 440H
B400 HG-5000 w/5083, CNC Head, HS-65HBs / B400 GY401 w/3400g, JR285s
T-Rex 600E / 600N Pro
mr2mkii is offline        Reply With Quote
Old 02-10-2009, 05:19 PM   #11
Propaganda
When I got my Blade 400 it was off as well. Swashplate was not level either. Watch Sokal's videos (a big thanks to that man!) and set it up properly.
Propaganda is offline        Reply With Quote
Old 02-11-2009, 04:27 PM   #12
Helihangover
Default Making Progress
Well i started from scratch. Set the swash up level with 16.25mm Gap as per the PNP manual showed.(thanks for the link 1badair). Then set up the rest of the way like the book showed.. Problem was Long rods that went to the bell mixer arms. They were over 2mm off from the factory. Adjust them as per manual. Then checked swash and adjusted to fine tune..
New measurements are a lot better.
Normal +11/0/-2
Idle up +11/0/-10
Will this work or do I need to do anything else to fine tune?..Way to windy to test it out today..
Old 02-11-2009, 04:36 PM   #13
sokal
Normal +11/0/-2
Idle up +11/0/-10
raise your swash 1 1/2 turns on all 3 swash to servo links
then recenter washout arms and 0 pitch blades
you may also have to lower your pitch swashmix setting a lil to get +10/-10
if not then raise swash 1 1/2 turn till the range is equal just remember each time you adj swash you have to recenter everything above it to level and 0 pitch at mid stick
the measurements in the pnp manual is ok but its not exact
but will get you in the ball park
Old 02-12-2009, 04:42 PM   #14
Helihangover
Default What's Wrong Now?
I am puzzled now. Tried my blade out today after getting the head set right. Pitch gauge shows+10/0/-10 in idle up, +10/0/-2 normal mode.. But when i tried to lift off, it wouldn't go up.. At full pos in idleup it would start to get light on her feet but that is all it would do.. Rechecked the pitch, and it had not changed.. But no lift.. I watched the swash plate while trying to lift off, it was going down like it should. The head speed sounds a lot higher now then before.. I am lost ....Any Ideas???
Old 02-13-2009, 10:53 PM   #15
sokal
any luck?
Old 02-13-2009, 10:55 PM   #16
sokal
check your seesaw may be cracked
and once thier force on the blades it flexes
Old 02-13-2009, 11:53 PM   #17
1BADAIR
what are your pitch and throttle curves?
Old 02-14-2009, 06:45 AM   #18
leeok75
Im only a newb but should'nt the swash be going up when adding throttle?
leeok75 is offline        Reply With Quote
Old 02-14-2009, 08:52 AM   #19
sokal
if your grips are fliped yes
Old 02-14-2009, 09:51 AM   #20
d3x0r
I think it was similar settings on my blade out of the box aswell, i have changed servos and zero pitch point with all 65s at 90 degrees was +5 or even +6, it probably was same with old servos because i have mounted ballinks in almost same place on servo horns. but now it seems to be ok
| TZ V2 Frenzy | GY401/9254 | TT RedLine 53H/TT HiFlow Muffler | REVMAX | 20% Bekra |
| B400 | HS65's | GY401/9257 | CCBec | Turnigy 2836/40A esc | Sonix Head/Alu Frame |
| HK250 | Blade mCX |
Parts shopping, repairs, swash leveling, punctuated by brief periods of flight...
d3x0r is offline        Reply With Quote
