Old 02-12-2009, 05:32 PM   #1
Pipes
Default Blade 400 Too hard on landing
I spolled up my Blade 400 and found when I bring the Throttle stick down it hits the ground hard. Is there a way to fix this son that it can be lowered with a little les down force.
Keep on Flying
Pipes is offline        Reply With Quote
Old 02-12-2009, 05:34 PM   #2
1BADAIR
are you in normal mode(not idle up)?
if so check out the b400 bible for some better pitch curves
I think this is whats recommended in the bible
Pitch Curve: 41/46/50/75/100
Throttle Curve: 0/15/30/45/60
Compass 7HVU HBL980/950 Ar7200bx Edge160-- Compass 6HV, 610/650
TRex 700LE , Beastx 610/650, Warp360 TracX 92A+
1BADAIR is offline        Reply With Quote
Old 02-12-2009, 05:41 PM   #3
Pipes
I have picth Curves 40, 42.%, 50.% 75% 100%
Throttle 0, 25% 50% 75% 100%
Are these wrong
Keep on Flying
Old 02-12-2009, 05:54 PM   #4
Atomsk
That throttle curve seems a bit on the low side, I would recommend more headspeed not less IMO.
I run a Throttle curve of 0-60-70-80-90 on normal mode.
MSH Protos CF - DS3517MG Cyclic, S9257 Tail, Spartan DS760
Blade 400 - DS285MG Cyclic, DS290 tail, Align GP750, HobbyWing UBEC, aluminum upgrades.
Honeybee CP2 with SuperSkids (RIP)
Blade MSR
Atomsk is offline        Reply With Quote
Old 02-12-2009, 05:54 PM   #5
Arsenix2001
Two words, collective management - In laymans terms, learn how to use your thumb. It is sensitive as hell, so practice finding the hover point, getting it light on the skids and setting it down softly.
Why oh why, did it fall from the sky?
E -Flite Blade 400 3D and MCX, Align TREX 600NSP, Traxxas Nitro 4-TEC 3.3, Traxxas Nitro TMAXX 3.3, Enforcer 48" 30cc Gaser Deep V fiberglass boat
Arsenix2001 is offline        Reply With Quote
Old 02-12-2009, 05:57 PM   #6
helidude3
your curves should be 46, 48, 50, 75, 100
helidude3 is offline        Reply With Quote
Old 02-12-2009, 06:37 PM   #7
Atomsk
Well, for pitch curves you should set the first point to whatever gives you about -2 degrees of pitch at low throttle, then point 2 should be an interpolation between that number and 50, and then P3 P4 P5 should be 50, 75, 100.
Blade MSR
Old 02-12-2009, 07:57 PM   #8
mr2mkii
+1 This is what I run with as well. Typical hover is 70-75% throttle with 3-4 of positive pitch, so that curve allows it to be less sensitive in that area.
Blade mCX / mCPx / 130X / B400 HS-65MGs FBL CopterX w/3400g CCBEC 440H
B400 HG-5000 w/5083, CNC Head, HS-65HBs / B400 GY401 w/3400g, JR285s / B450X
T-Rex 600E / 600N Pro / Vortex 250 Pro
mr2mkii is offline        Reply With Quote
Old 02-12-2009, 08:05 PM   #9
Slyster
If you are just hovering.. therefore no windy days.. feel free to try 50-50-50-75-100
Will plop down very gently even at full negative stick!
Also.. check with a pitch gauge to be SURE that you are really at 0 pitch at mid stick!
I've heard some brand new ones so far off they were like +7 or even in the negatives at mid stick.
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 02-12-2009, 08:08 PM   #10
Propaganda
Amen to that. Go through Sokal's videos and make sure your Blade is mechanically setup correctly.
Propaganda is offline        Reply With Quote
Old 02-13-2009, 11:09 AM   #11
neilg.
why not change the -3 at 0 stick to something else
neilg. is offline        Reply With Quote
Old 02-13-2009, 11:20 AM   #12
HeliMatt50680
Yeah, more pitch at lower throttle will make landings nice and cushy.
If you wanna live life by your own terms you gotta be willing to crash and burn.
Blade 400, Blade CX2, Blade CP (retired), Traxxas Revo & Slash, Jammin CRT/BCE, Hobao Hyper 8.5, All Spektrum controlled.
HeliMatt50680 is offline        Reply With Quote
Old 02-13-2009, 11:27 AM   #13
Atomsk
Keep in mind that if you don't have any negative pitch available the wind will have its way with your poor blade 400 and you may not be able to set it down when you want to if its windy.
Blade MSR
Old 02-13-2009, 11:37 AM   #14
neilg.
good point
it will land but not where you wanted it to
Old 02-15-2009, 09:34 AM   #15
macel
sly is right my one had about minus 13, - 3 at mid and plus 2 at full collective............ OUT OF THE BOX, thick as i am i only realised that after i crashed it whilst starting......as i had no lift almost but as soon as i gave right cyclic it tilted and cartwheeled on the ground............. first thing get a pitch gauge check the factory settings.......
macel is offline        Reply With Quote
