Old 02-18-2009, 07:01 PM   #1
jcivic
Default ESC Problem?
Hi, so my problem is, that when i spool up my 250 it will go good for about 15-20 seconds, then it will shut down and try and restart but wont ( it loses all power and acts like i just plugged the battery in). it also get really hot! is it bad or what is going on? it only has like 10 flights on it, no 3d just hovering.
thanks for the help.
Blade MCPX, Trex 450 pro FBL, Trex 500, DX7
jcivic is offline        Reply With Quote
Old 02-18-2009, 07:40 PM   #2
Ozz58
The ESC is over heating.
Check if your belt is too tight first. If it's ok, look for any binding in the servos or links.
Did anything happen or did you change anything after the 10 flights you said were good?
Craig
Ozz58 is online now        Reply With Quote
Old 02-18-2009, 11:06 PM   #3
jcivic
Ok check everything out and found nothing, belt is good, servos are good, and no binding. just not sure what it could be.
and i have not changed anything from when i first set it up.
Old 02-19-2009, 11:07 AM   #4
dingfangle
I bought one of the first 500's when they came out and had a problem with it's ESC befor ever flying the machine. I contacted Assurance rc the north american distributor for Align and they sent a replacement ESC right away. You may have just gotten a bad unit.
hope this helps and good luck
Needs to be updated. I keep buying more stuff, Damb this hobby!!!
dingfangle is offline        Reply With Quote
Old 02-19-2009, 08:48 PM   #5
jcivic
I bought it from Grandrc.com, do i need to go through them or grandrc.com?
Old 02-20-2009, 12:50 AM   #6
cbrian4
Are you using the DS420 Tail servo? Those have been known to basically suck and overheat your esc. Be careful, some have fried theres. Try using a different tail servo
cbrian4 is offline        Reply With Quote
Old 02-20-2009, 09:14 AM   #7
jcivic
Well i did notice the tail servo (ds420) was really hot. i will disonect that and give it a test spool.
