Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4#3, 4#3a, 4#3b, 4#3Q
4#3, 4#3a, 4#3b, 4#3Q Walkera 4#3, 4#3a, 4#3b, 4#3Q Helicopter Support
Old 02-18-2009, 11:51 PM   #1
mbaran
Default Best Replacement Tail Rotor Shaft
So I got my 4#3B last night. I've got good experience on an EF Mash coax so after 10 or so hard crashes I got it to hover okay.
I did happen to break the CF tail rotor shaft, the rotor fell off. For now, im using a bent up paperclip just so i can fly it.
I read one good mod, was the shaft from an old tail motor. Is this still the best setup. I was going to just buy a new tail rotor, and a spare motor (only 4.50 from wowhobbies) and pull the shaft out and use that..
Thanks!
mbaran is offline        Reply With Quote
Old 02-19-2009, 05:19 AM   #2
BlackBeast
You can also use shaft from main brushed motor.
Hobbyking Yak-54 with SuperTiger .10 - Parkzone Extra 300 - SkyAngel F-16 and F-18 EDF 50mm - Blade 400
BlackBeast is offline        Reply With Quote
Old 02-19-2009, 09:33 AM   #3
Dusty1000
The bent paperclip may just bend your bearings. For the short term I would cut the canopy rod, use it, and find something else to hold the canopy on with
Blade 400, mSR, mCPX - Sonix SX450SE - Walkera 1#A, 4#3, 4#3A, 4#3B, 4G3
Dusty1000 is offline        Reply With Quote
Old 02-19-2009, 04:28 PM   #4
mbaran
Last night after a hit I lost the little rubber stopper on the other end. Any suggestions as to what works as a good alternative. If I use the motor shaft does it need any stopper still?
Thanks!
Old 02-19-2009, 04:50 PM   #5
al_evans
I've successfully used a little piece of heat-shrink tubing, maybe with a little CA if it's not tight enough.
Myself, I wouldn't trust friction alone to hold it in place. I don't want to be looking for those little bearings....
--Al Evans
al_evans is offline        Reply With Quote
Old 02-19-2009, 10:26 PM   #6
john aeras
One other thing you could use is a small piece of thin wire insulation. (usually off alarm or thermostat wire)
Some people have a problem for every solution...
john aeras is offline        Reply With Quote
Old 02-20-2009, 08:12 AM   #7
BlackBeast
I built a tutorial for tail rotor shaft. Look at it and tell what you think...
http://rcfriends.createforum.com/wal...rial-t136.html
Old 02-20-2009, 12:28 PM   #8
john aeras
http://membres.lycos.fr/cqtranstemis...t_totorial.htm
Excellent job Blackbeast!!
I think this one should should become a "sticky"
Any admins watching?
Old 02-21-2009, 10:21 AM   #9
Dusty1000
Nice one!
now I have a use for all the pinions on old motors I have lying around
Old 02-21-2009, 10:41 AM   #10
al_evans
Great tutorial!
I tried this yesterday, and it worked well -- unfortunately, somehow I slightly bent the motor shaft. I'll just wait for another dead motor
--Al Evans
Old 02-21-2009, 11:18 AM   #11
BlackBeast
Originally Posted by Dusty1000 View Post
Nice one!
Thx john aeras, Dusty1000 and al_evans.
Normally, unless you own more than one 4#3s, you will only need to use one shaft and two pinions. It's almost UNBREAKABLE!
