Old 02-19-2009, 07:39 PM   #1
GaFlyer
Default Charging 2*3S batterieson w/TP610????
Can you charge/balance 2 3S batteries and if so how?
GaFlyer is offline        Reply With Quote
Old 02-21-2009, 11:50 AM   #2
dbertheau
You probably can charge using a Y adapter and charging as a 6S; but I'm not sure you'll be able to balance.
dbertheau is offline        Reply With Quote
Old 02-21-2009, 12:28 PM   #3
TheBum
With series adapters for the main leads and balance leads, you could charge it as a single 6S. Alternatively, with parallel adapters, you could charge them in parallel.
The advantage to parallel charging is that the packs can be different capacities, different charge levels, and different ages. The only limitation is that they have to be of the same cell count, which isn't an issue in your case.
Series charging only really works well if the packs are of the same capacity, charge level, and age. If any of those properties are not present, it may take much longer to charge and balance, if the charge completes successfully at all.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
Old 02-21-2009, 09:15 PM   #4
GaFlyer
Hey guys thx for response, and dbertheau thats what I was wondering about the balancing of them charged in series or parallel. I was hoping for someone who has charger to respond but I guess it aint being done with this charger. Thanks again
Old 02-21-2009, 10:13 PM   #5
dbertheau
I have 2 TP610s - only charge one battery at a time on them. I also have a Bantom BC8dx, which I charge two sets of two 3S'. Charge 6 batteries at a time with the three chargers.
http://helifreak.com/showthread.php?t=120924
Old 03-19-2009, 08:53 PM   #6
shaggybirdman
my icharger 1010B+ can do 3 3s packs at one time via there balance board. check it out at A Main Hobbies
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote
