Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 04-23-2009, 11:56 AM   #21
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Originally Posted by Brett74 View Post
Hey Guys
Where do you get that cools braided stuff you put on your servo wires and what is it called? I am currently building a 600 esp.
http://www.readyheli.com/SearchResul...earch=sleeving
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is online now        Reply With Quote
Old 06-17-2009, 11:44 PM   #22
BBRFST
Originally Posted by TheBum View Post
oops
Atom 500 VBar (Takes a licking), MCPx 2s (Flying
), Atom 7HV-Bar (Flying LARGE!!)
BBRFST is offline        Reply With Quote
Old 06-23-2009, 01:12 PM   #23
KDE Direct
Finless just finished a great (and rather hilarious) review of the T700N and T600N Aluminum Thrusted Bearing Blocks in his Tech Room at:
http://www.helifreak.com/showthread.php?t=146290
Check it out, it's definitely worth the entertainment.
-- KDE Direct, Inc. --
KDE Direct is offline        Reply With Quote
Old 06-24-2009, 12:48 AM   #24
BBRFST
Default Thank You
Just wanted to say thank you kegerator for putting out great products and Finless for sharing them with us. I don't fly as hard or as frequently as the guys I hang out with but after a few gallons these bearings are still smooth as silk. You guys are a real blessing to the heli community keep up the great work!
Old 07-06-2009, 12:42 AM   #25
gabe_es
Just ordered the Gyro Mount from www.readyheli.com for my Spartan DS760. I figure with using the G-Force servo adapter plate and an 11gm throttle servo solution, the weight won't make any different at all or throw my CG off. Love the bling!!
Trex 600NSP -TT Redline 53 / CY MP5 / 3x HS-7940THs @ HV/ HS-5065MG throttle / HS-65MG on Carbsmart / BLS251 Tail/ SG ReactorX2 Regulator / Mikado V-Bar Blueline 5 Pro / Switchglo Pro / JR X9303 / CYE Radix FBL 600 Mains / CYE 95mm Tail
gabe_es is offline        Reply With Quote
Old 03-08-2010, 05:53 PM   #26
tracvision
that damn processor is way too cool.
tracvision is offline        Reply With Quote
Old 11-16-2010, 01:02 PM   #27
cklking
Default FLYBARLESS MAIN ROTOR HOUSING
Sweet!!!
Align Trex 450 SE V2 w/ Super Frame
Align Trex 500 CF
Align Trex 600 ESP Quark
Align Trex 710 Stretch 3G 4035 630 CC80HV 10s
cklking is offline        Reply With Quote
Old 11-18-2010, 12:17 PM   #28
Felt
Does the new FBL main rotor housing lower the height of the main rotor blade? I am wondering if it does this like the RJX housing.
Felt is offline        Reply With Quote
Old 11-20-2010, 09:03 AM   #29
cklking
Why yes it does. I bought the new ALIGN 600FL Main Shaft HN6118 and the ALIGN 550EFL Linkage rod(A) set H55047 to line up the missing 10mm.Charles
Align Trex 500 CF
Old 11-20-2010, 01:27 PM   #30
philipfrank
on the 550e, the head height is the same. it is a nice peice.
philipfrank is offline        Reply With Quote
Old 06-23-2011, 03:03 PM   #31
Azalin
I installed the AT600N-MBB TREX600N THRUSTED METAL BEARING BLOCKS to my 600LE but noticed that the elevator arm inside is touching to the upper bearing block and the only way i think is to upgrade the elevator arm too but i don't know if there is such arm. I think this set is not designed for 600LE. It is designed for the first Trex 600 Nitro. I feel like unhappy and disappointed.
Trex 700 Gasser FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX270TT | SG | RJX Gas muffler | JR x9503
Trex 600 Gasser FBL | HeliBug HB6-RC7 20T | Brain | GV-1 | Stock Zenoah G290RC | RJX pipe | JR x9503
Azalin is online now        Reply With Quote
