Go Back   HeliFreak > R/C Batteries and Charging Support > LiIon, LiPo, NiCd & NiMh General
LiIon, LiPo, NiCd & NiMh General General Battery Support
Old 02-21-2009, 05:09 PM   #1
shacho
Default Lipo -vs- NiCad/NiMH Batteries
I am considering swapping out the NiCads batteries for Li-po and I know I will need a step-down to regulate the voltage. Q: What is the best setup to prevent destroying the servos? My first thought is to install the step-down pig-tail between the receiver and the battery. Your inputs and thoughts are greatly appreciated Thanks.
shacho is offline        Reply With Quote
Old 02-22-2009, 12:22 AM   #2
TheBum
A step-down probably wouldn't support high enough current. You'd be much better off with a BEC.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
