Old 03-04-2009, 10:19 AM   #1
groundprox
Default Main Shaft
Does anyone here know what the dimensions of the main shaft? In particular the thickness of the shaft? I guessing that its 8mm thick, but I couldn't find it in the manual.
groundprox is offline        Reply With Quote
Old 03-04-2009, 11:09 AM   #2
EricW
8 mm, L=151
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRTOS
EricW is offline        Reply With Quote
Old 03-04-2009, 11:21 AM   #3
groundprox
Old 03-08-2009, 03:28 PM   #4
tailStrike
While we're on the subject, what about the hollow vs. solid steel shaft? The hollow is stronger I suppose? $2.50 more a piece at readyheli so I'm just curious if it's worth the extra dough.
Buy, buy, buy? Dude, just fly.
tailStrike is offline        Reply With Quote
Old 03-08-2009, 03:50 PM   #5
Melly
The hollow shaft is lighter. Less weight is what you pay.
Melly
MSH Protos FBL AC-3X
Align T-Rex 250SE Gyrobot 700
Melly is offline        Reply With Quote
Old 03-08-2009, 04:30 PM   #6
Chorge
...and stronger! A tube is (if correctly dimensioned) alwas stronger than a massive shaft...
Chorge is offline        Reply With Quote
Old 03-08-2009, 08:22 PM   #7
tailStrike
That's not what she said.
Old 03-09-2009, 12:10 AM   #8
kgfly
That a tube is stronger than an identical shaft of the same material is often quoted but not true AFAIK. If you can explain the physics as to why it would be so I would be interested to learn.
The hollow shafts are lighter and have to be bored out. More machining = more cost = higher price.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote
Old 03-09-2009, 04:01 AM   #9
HighFreq
Hollow tubes of same size being stronger than solid is the most common misconception in mechanics.
If the diameter is the same a solid tube of same material is always stronger than an hollow one.
True is that if with the same amount of material as a solid shaft one would build a larger shaft hollow inside than it would be stronger.
You are absolutely right about higher prices on hollow shafts as they are bored one by one on the cnc machine.
Corrado
www.msheli.com
HighFreq is offline        Reply With Quote
Old 03-09-2009, 02:06 PM   #10
mlucia
What is the weight difference between the hollow and solid shafts?
http://madcow-productions.com/mluciaheli
mlucia is offline        Reply With Quote
Old 03-09-2009, 03:36 PM   #11
simmer
it has to be 1/3 or more "less weight" than the solid. Every little bit adds up!
simmer is offline        Reply With Quote
Old 03-10-2009, 12:14 PM   #12
Melly
MSH51004 hollow shaft (2pcs+screw+washer+plastic bag) = 62g
MSH51080 solid shaft (2pcs+screw+washer+plastic bag) = 119g
So the hollow shaft is 30g an the solid is 58g.
Melly
Old 03-10-2009, 08:48 PM   #13
mlucia
