Go Back   HeliFreak > R/C Simulators Support > Phoenix Flight Sim > Phoenix Custom Creations
Phoenix Custom Creations Phoenix Flight Sim Custom Models and Fields
Old 03-04-2009, 01:19 PM   #1
puzom
Default Post your SOUNDS here.
Hi,
Post your sounds here please.
Some great ones by devindh:
PhoenixRC_resources_soundEffects_helicopters.zip
PhoenixRC_resources_soundEffects_misc_wind_sound.z ip
nitro_w-hatori.zip
nitro_w-hatori_better.zip
nitro_w-align.zip
Also test the sound modes in PhoenicRC to see which sounds the best. On my system it's OpenAL.
Cheers!
puzom is offline        Reply With Quote
Old 06-10-2009, 01:18 PM   #2
Ecaf
Default Protos sounds....
For when they arrive in 2.5...
elektrorc.com
mini-PRTOS - MSH Brain
SAB Goblin
μBeast
Ecaf is offline        Reply With Quote
Old 06-21-2009, 12:18 AM   #3
devindh
Originally Posted by puzom View Post
Hi,
nitro_w-hatori.zip
nitro_w-align.zip
Cheers!
Update for 50, v2.5
Pls extract to ...\PhoenixRC\resources\soundEffects\helicopters
Get all *01,*02 and *03 for all files needed (due to attachment file size limit).
included backup from original wav files,....
Rgds.
devindh is offline        Reply With Quote
Old 07-09-2009, 08:44 AM   #4
puzom
Hi,
Is the Outrage 550 sound any good? Running governor at 3000 rpm.
Cheers.
Old 07-09-2009, 08:51 AM   #5
CeeveeSiN
Hi,
YouTube - Outrage550soundcheck
Cheers.
sounds quite good to me.. i'll be downloading Devin's sounds tonight was hoping he'd update them for 2.5
SAB USA Field Rep, Skookum Field Rep,
Team Lynx
Goblin 700, Goblin 630, Goblin 500
CeeveeSiN is offline        Reply With Quote
Old 12-09-2009, 05:57 PM   #6
puzom
Hi,
For the EDF users:
EDF sound here http://www.helifreak.com/showpost.ph...5&postcount=65
Cheers!
Old 12-10-2009, 10:25 PM   #7
Raynman
I xtracted the sounds into folder as mentioned above - cant seem to find them on my phoniex sim tho?
I am running the latest version of phoniex (t)
Compassmodel / Savox / BavarianDemon / Fusuno / Rotor-tech / Revolectrix / Mks-servo / www.hobbyhangar.co.nz
Raynman is offline        Reply With Quote
Old 12-11-2009, 05:26 AM   #8
puzom
Hi,
Which sounds did you use?
For planes:
*.pxe in c:\Program Files\PhoenixRC\resources\objects\aircraft\fixedWi ng\engines\
*.wav in c:\Program Files\PhoenixRC\resources\soundEffects\planes\
For helis:
*.pxe in c:\Program Files\PhoenixRC\resources\objects\aircraft\helicop ters\engines\
*.wav in c:\Program Files\PhoenixRC\resources\soundEffects\helicopters \
The heli sounds are replacing the old ones. My EDF sound is new and you can use it by selecting EDF in the sound setup of your plane.
Cheers!
Old 12-11-2009, 05:30 AM   #9
puzom
Default EDF sound for models with 2 Fans
Hi,
New EDF sound for models with 2 Fans, eg the Typhoon EDF
Select "EDF 2 Fans" as engine in model sound setup
Run "EDF" engine first and than the "EDF 2 Fans", you should notice a difference
Share your thoughts!
Cheers!
Old 12-11-2009, 06:22 PM   #10
Raynman
Still having probs ....... PUZOM .........Ok I'm gonna start again ....... Can you take me tru it step by step plz?
I just want the heli sounds.
Cheers
Raynman,
Old 12-12-2009, 12:01 PM   #11
puzom
Cheers
Raynman,
What file did you copy where? And what are you missing now?
Old 12-12-2009, 01:10 PM   #12
Raynman
I deleted all the sounds I extracted into a folder that has been deleted now - I just wanted to start again from the begining.
At the moment I have no sounds and No folder to xtract them too.
Which heli sounds shall I copy? Wot folder shall I xtract them too?
Not sure if I am making sence here?
Old 12-12-2009, 01:53 PM   #13
puzom
Get all the files from post #3, click all links. Unzip the WAV files into:
Old 12-13-2009, 11:40 AM   #14
l-fever
I just purchased 2.5 and upgraded to 2.5t. I'm not happy with some of the sounds like the trex 500 sounds more like a truck than an electric heli. Should I used the sound files posted above? TIA.
l-fever is offline        Reply With Quote
Old 12-13-2009, 11:58 AM   #15
puzom
Yes get them all
Old 12-13-2009, 01:27 PM   #16
l-fever
Yes get them all
Will do! Thanks!
Old 01-03-2010, 06:05 PM   #17
raylepper
Yeah the Trex 500 sound is awful. But I was able to make it a bit better by doing this:
I copied the file heli_500_gearless_100%.wav, deleted the file heli_500_100%.wav, and renamed the copy as heli_500_100%.wav.
It sounds a LOT better. Still not really right though. I wonder, does Phoenix sample the actual sounds our helis make?
raylepper is offline        Reply With Quote
Old 01-31-2011, 05:59 PM   #18
puzom
- Velocity 50 sounds here: http://www.helifreak.com/showthread.php?t=246486
- Trex 700E
sounds here: http://www.helifreak.com/showthread.php?t=275611
