Hi guys, I'm just after a good swashplate mix setup for my DX6i to use on my Trex 450.
Thanks Michael
T-Rex 450S Upgraded T-Rex 500 Spektrum DX6i E-Station BC6 charger |
DX6i numbers generally run high....
Don't rely on others for numbers...it depends on your equipment and your setup... What is important is to get the blades to do what you want....so measure your collective and cyclic pitch and then use the mix to go up or down in value. Something that gets you +-11 for collective and +-6 for cyclic for starters.
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
Just checked my dx6i....I'm at 80 for all of them....not sure if you'll need them to be positive 80 or negative 80...you'll have to figure that one out(depends on your servos)
Thanks guys, I was thinking of around 75 as that's what I had setup for my blade 400 but I might change the settings to 80.
Got 80 for both Aile and Elev, gives about 7 degrees on both and 90 for Pitch, gives 12 degrees up and down.
