or the bird crashed into me.....oh well i nursed him and he took off like a bat out of hell
how bad did you messup the heli, were you in norm or idle 1.
idle..........i recoverded bout 4 feet from the ground...........heli fell bout 40 feet
I hit a Seagull one day killed the bird and totaled my 450XL it was gross!
Radical G20, Trex 500, Trex 450 Pro, T-28 Trojan, Twin Cam 95CI W/ 10:1 comp pistons, Gear driven cams, Screamin eagle pipes, Big air kit, race tuner. |
I have nearly hit a eagle it was chasing my heli like it wanted to mate with it i put her down and waited for it to piss off !!! LOL i didnt want to see the mess my heli would have made to it and my heli
"So What is 3D Flying" Definition: 3D as applied to current rc helicopter flying is any maneuver that to be performed requires the constant harmonized input of three or more controls simultaneously while the maneuver is taking place. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#6 | |
One of the guys on RCuniverse did that on his maiden flight with an HBK2 and completely destroyed his heli. We all rallied together and pitched in to buy him a new one.
TREX 500ESP,Scorp 1400/15t, ICE100, AR6200, 510, 3G + 520,EDGE FBL main Coptex 450pro, Scorpion -8 w/13t, -8 CC45, AR6100, 65MG, GP8750 + 9257 Copterx Black Angel 450, Scorpion -8 w/13t, AR6100, 65MG, GY240, DS520 |
#7 |
Poor seagull... Those things are often older than I am. It seems a shame when they die.
I once had my heli chased by a seagull who decided, at the last moment, to break off. I never knew a seagull's turning radius was so small. It was actually very funny. On a bicycle, there's a debate about whether to try to avoid cats, squirrels etc... and I think the consensus is to hold your course - you're more likely to hit them if you both take evasive action as then neither knows quite what the other is going to do. I suspect, though I don't know, that holding one's ground with a helicopter is also the best course of action. Most birds are maneuverable enough to hit a helicopter if they really want to so making them believe that you're meaner and badder than they are is actually probably the best course of action. |
#8 |
The Magpies around my area are regularly having a go at my helis, wether its my 450 or 600. When they get to about 4-6 feet away, the birds start backing off real quick. Agile little buggers.
Even the Willy Wag Tails like to have a go and they are only as big as your hand. |
#9 |
[quote=wlfk;1180680]Poor seagull... Those things are often older than I am. It seems a shame when they die.
Seriously??! These things are flying rats! If I could figure out a way to take them out of the sky without f'ing up my heli... I'd build it. |
#10 |
I have had Red Tailed Hawks have a go at the 450 about five or six times over the last couple of years. It has happened at different locations all over the US. They come out of no where and dive on the heli. I think it's a territorial thing. They always look serious and are usually tucked in a dive with talons coming out when I see them and going very fast. They don't look like they are going to back off so I always bring it down like a powered brick and land. I have had them hang around after I landed and latter take off again. They usually have another go.
T-Rex 450 SE, 430L 13t, Align 35A ESC, 325 Pro, JR 6102DX6, GY401, 9650, HS-65MG'S. |
#11 | |
Try holographic blade stickers, they work here!
How much past 200 mph do I need to go you ask? |
#12 | |
#13 |
I had a bat try to make out with my transmitter once....maybe it heard some kind of mating call coming out of it...AM 27mhz rc car stuff. I probably looked like a fool doing some kind of sword fight with the thing!!
Trex 450 Pro 3xDS410M + MKS8910A+, Align FBL head w/Microbeast, CC 45 Gov@ 3400rpm(max timing, outrunner mode), Scorpion 2221-8 on 14t, Edge FBL main and tail, CF boom, CC BEC @ 6V |
#14 | |
#15 |
I hooked a bat flyfishing not too long ago.
The bat grabbed my fly just as it was hitting the surface of a glassy pond. He started to fly away taking my fly line into the air. If you don't know what fly line looks like it's thick and usually brightly colored. It was very strange to see my line going up into the darkening sky instead of down towards the water. Anyway I reeled him in and pinned the bat down on the ground with my net. At that point the hook fell out of the bats mouth and he flew away when I lifted the net. ...good thing because I'm not sure how I would have released him otherwise. Sorry, I couldn't resist telling that story for any other fishermen out there. Now, back to our regular programming.
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
#16 | |
#17 | |
Speaking of bats....did anyone see the episode with a bat in The Office....guy catches bat while it is on someones head....funny!!
#18 |
you didn't end up in a river did you???
#19 |
Yes I did.
#20 | |
As for birds, I have gone 'pigeon wrangling' with my Blade CP Pro and Trex. There are about a hundred of them in the ball field I fly in on weekend mornings. They take off en masse and wheel and whirl as a group to avoid the helicopter.
Trex 450 SE V2 T-rex 500 ESP |
