Old 06-06-2006, 11:40 AM   #1
misio
Default Stratus bearing size - list
I’m trying to make a list of all bearings that stratus need for replacement. So far I was able to get this. If any one knows bearing size please post and I will update list
120-12 upper main shaft bearings block – 2x 10-19-5mm
120-8 main shaft/tail drive bearing block – 10-19-5mm + 2x 5-10-5
115-18 lower main shaft bearing block – 2x 10-19-5mm
126-66 front T/R bearing block – ? flanged
Clutch bell unit
Bearing block –
Upper 111-8 – 6x17 flange
Middle 0199- 6x19x5
Lower 0183 – 10x19x5
Driver bearing big one 10x19x7
Clutch bell 6x10x5 - flanged
Blade grip - 2 each 8x16x5 plus thrust bearing
Flybar carrier/pivots in the head 4 - 6x10x3 Flanged
Tork tube – 1 or 2 9.5mm x 15.8mm
Bellcrank bearings
6x M3x7x3 Flanged
2x M5 ? Flanged
If you have any info please post and I will updates list for every one, I will add size for open box, head etn.
misio is offline        Reply With Quote
Old 06-06-2006, 03:13 PM   #2
ChrisLaFollette
The bearing in the clutch bell is a 6x10x5.
Blade grips are 8x16x5, 2 in each grip and a thrust bearing in each grip.
The bearing that the pinion inserts into, the one in the bottom of the bearing block is a 10x19x5.
I know pretty much all the dimensions by heart and I will get back later with the rest of the dimensions.
ChrisLaFollette is offline        Reply With Quote
Old 06-06-2006, 04:02 PM   #3
misio
Thanks for that info, list is updated, stylle need more
Driver bearing bethen driver and clutch ( big one )
tork tube ?
Old 06-06-2006, 05:03 PM   #4
angelob
The flybar carrier and pivots in the head are 6x10x3 flanged - qty 4
#KeepRCHelisAlive
angelob is offline        Reply With Quote
Old 06-06-2006, 05:22 PM   #5
ChrisLaFollette
Heres a full list.
All mainshaft bearings are 10x19x5 bearings non flanged
Main Grip bearings are 8x16x5 non flanged
New flybar carrier and carrier pivot bearings are 6x10x3 flanged
Clutch bell bearing is 6x10x5 non flanged
Top clutch block stack bearings is 6x17x5 flanged
Middle bearing is 6x19x5 non flanged
Lower is 10x19x5 non flanged
Driver bearing is 10x19x7 non flanged
Torque Tube bearing is 9.5x16.. er like 15.8 actually x 4 non flanged
All I know off the top of my head. I dont have the one piece block for the middle mainshaft bearing block with the front drive gear bearing thing.
Old 06-06-2006, 10:35 PM   #6
misio
thanks for info
Torque Tube bearing is 9.5x16.. er like 15.8 actually x 4 non flanged ???
and one more for now
Old 06-07-2006, 02:53 PM   #7
ChrisLaFollette
The torque tube bearing wasnt quite 16 mm it was actually about 15.8 and the ID was about 9.5.
Measured with calipers.
Old 10-25-2007, 02:11 PM   #8
rotrap
Default Torque Tube bearing
Inner diam 3/8 (9.525mm)
Outer diam 5/8 (15.875mm)
Width 5/32 (3.967mm)
R1038
/Henrik
rotrap is offline        Reply With Quote
Old 10-25-2007, 02:25 PM   #9
DavidH
The thread is nearly 1 1/2 years old. LOL
Chris is no longer around anymore. Look in the Stolen section and you will see why.
David
DavidH is offline        Reply With Quote
Old 10-25-2007, 02:34 PM   #10
rotrap
David
I know the thread is old! just trying to help people, as i searched for a while since here in sweden inch bearings isn΄t that common ;-)
/Henrik
Old 10-25-2007, 02:40 PM   #11
DavidH
MA uses bearings that have metric dimensions. Yes any bearing the size can be posted in inches or millimeters. MA has always used metric measurements for the bearings they use. The bolts are also metric, as is most of the parts on the heli.
Just found it amusing someone would drag out a thread old as this one.
David
Old 10-25-2007, 10:39 PM   #12
misio
Wink
David
Just for onec get a beer and be positive with your live.
Old 10-26-2007, 08:40 AM   #13
DavidH
I am positive with my life everyday. Waking up each morning is positive. LOL
David
