Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Electric Conversions
700 Electric Conversions Align T-REX 700 Electric Conversions
Old 03-23-2009, 06:30 PM   #1
Finless
Team Taco VP
Default Trex 700 Electric conversions
It was suggested to me to make a sticky for 700 Electric conversions.
So here you all go! Post away!
Bob
Old 03-23-2009, 09:23 PM   #2
NolanManley
My Xera (4030-3Y 470) performed great in my 700E at Birmingham this weekend.
I let a much better 3D pilot fly it and he got 6:30 of hard 3D on it using excatly 4200ma on my 12S 5000 packs. Soon as he landed we felt the motor and batteries and they were just luke warm. Sorry no temp guage but I never had to take my hand off the motor for being hot.
I've gone 10 min at 1800 rotor rpm with my old man sport flying no problem. My buddy flew 7:30 min at 1800 and the 6:30 at 1925 rpm
164/16T for 10.25 to 1 gearing.
More pics in gallery.
Next to the 700N
Stratus & Protos.
Magnum Fuel, KBDD intl Products
NolanManley is offline        Reply With Quote
Old 03-25-2009, 08:06 AM   #3
boosst
i am also running the 16t pinion on my 700e and getting 6:00 of flight time with 12s 5000mah. i am running the CC110HV...is that what you have on yours? what is your throttle curve set at in st2 and is there any bogging? i would love to squeeze out another minute out of mine.
Trex 500 ESP, DX7, AR7000, Spartan/3500g, Align cyclic x 3
Blade Eflite MCX, DX7
boosst is offline        Reply With Quote
Old 03-25-2009, 08:19 AM   #4
GenReaper
Thanks Bob.
I have a Build thread about my 12S setup located here - http://www.helifreak.com/showthread.php?t=113403
ATM im running 14 tooth pinion with 80 and 100 flat curves for Idle 1 and 2.
Getting 4:15 mins at 100 flat stick banging and could squeeze around 7+ mins out of 80 flat with sports flying.
PS : Mine doesnt bog even on 80% flat fixed end points mode no Gov.
I am currently also converting it to Flybarless with 3DX and SK360 setup so power and flight times should improve yet again.
Will add to my build thread soon when my head arrives from the USA.
Here is a picture as it is now and i am just making up a new Bracket to mount the SK module.
Trex 700E 12S Scorpion 4035-500 3DX SK360 Spartan 760 CC110
Trex 600E 10S Scorpion 4025-740 FBL SK360 Spartan 760 CC85
GenReaper is offline        Reply With Quote
Old 03-25-2009, 09:08 AM   #5
NolanManley
Boost, My buddy "Compuserve" on Runryder is running the Scorpion 560 on a 15 tooth pinion and he can get 8 min flights at 1850 rotor rpm. He has a HV85 using the 2.0 software and the Gov High mode.
Getting the speed % we just go in the transmitter and run up the curve in normal mode while someone tach the heli at flat pitch or slightly negative pitch to load the head. When it gets to what we want we make note of the throttle settings for each rotor speed we want and use that setting for the idle ups and normal mode. I've done this by myself and it's not hard.
Here's how it's suppose to be done but my numbers were off a little to the speeds I wanted so I used the above method for actual settings.
http://www.helifreak.com/showpost.ph...7&postcount=19
Stratus & Protos.
Old 03-25-2009, 10:39 AM   #6
LoveMyTrex
to me 700E's always look more slugish than 700N's am I crazy?
I was watching nolan manley's 700E be flown by Tristan at Bham and it looked way slower than jared granzow's nitro 700 and my own nitro 700.
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote
Old 03-25-2009, 11:52 AM   #7
Finless
Team Taco VP
Sluggish? Watch Tim Jones' E700 that I filmed at the Las Vegas FF. It's an animal!
http://www.helifreak.com/showthread.php?t=127382
Bob
Old 03-25-2009, 01:06 PM   #8
LoveMyTrex
that thing does have a ton of power, but all the 700N's I have seen can do all the same things, plus they have smoke
Old 03-25-2009, 01:08 PM   #9
NolanManley
Tristan flew mine at 1800 rotor rpm. I doubt that Jarod was flying his at that.
Tristan did say that my pitch seemed a little low. I'm at 11 deg. Remember I'm a sport flyer and rather get 8 to 10 min of mild 3D rather than 4 to 5 min of me scaring myself.
Not to mention I don't have a sponsor for batteries or kits. My stuff has to last. Batteries last longer if your not cooking them.
Stratus & Protos.
Old 03-25-2009, 01:19 PM   #10
LoveMyTrex
yep for 1800rpm it was doing pretty good.
I think jared is flying around 1920 with the YS, I am flying 1950 on the os HZ.
I just love the smoke and noise , you can really tell what the pilot is doing by the noise
Old 03-25-2009, 04:46 PM   #11
NolanManley
Yeah, that true. That's why I have the nitro too. But if I had to live with just one it would be the electric for my style of flying.
You may have seen Tristans 1st flight at 1800, his 2nd flight was more at 1925. The heli is 15 oz heavyer than the nitro.
Stratus & Protos.
Old 03-29-2009, 12:50 AM   #12
cbdane
Default Nitro Pro?
Hey, anybody notice that every 700 aftermarket canopy says "Nitro Pro"? Seems like the 700 electric conversion market is gaining steam and we need a generic 700 canopy. What'dja think?
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 03-29-2009, 07:10 PM   #13
NolanManley
That canopy in my first pic is the stock canopy that came with the heli's. All four of the 700's that I've built have had those canopies.
Stratus & Protos.
Old 04-01-2009, 08:22 AM   #14
xahhax
Does anybody have a 700E on 15S setup?
I have a 600ESP on 10S and potentially would look into 3x5S 3300mah for a 700E conversion. Any motor and ESC could handle this voltage?
Goblins 380/500/570/630/700
xahhax is offline        Reply With Quote
Old 04-01-2009, 03:56 PM   #15
docjoe
Here's my setup:
700E with HeliDirect conversion kit
Motor: Scorpion 4035-560 with 14T pinion
ESC: CC110HV
Receiver Spektrum 6200
Cyclic Servos 9452s
Logictec 6100T and servo combo
Batteries Zippy-H 20-30c 6s 5000MAH x 2 (12S)
Radix 690s
Stock Paddles
Stock Tail blades
I can do most of my 3D in Idle1 but straight 100% throttle curve is wicked nasty! I haven't tach'd it but it's 1900+ in idle 2. I can go 6 minutes of moderate 3D and put back about 3600MAmps back in the packs.
Joe
"Chancho, when you are a man, sometimes you wear stretchy pants in your room."
-Nacho Libre
docjoe is offline        Reply With Quote
Old 04-06-2009, 09:36 AM   #16
QYT001
Originally Posted by docjoe View Post
Here's my setup:
ESC: CC110HV
Cyclic Servos 9452s
Radix 690s
Stock Paddles
Stock Tail blades
What is the weight of your heli?
QYT001 is offline        Reply With Quote
Old 04-11-2009, 07:27 AM   #17
R-4-L
Here's my setup:
ESC: CC110HV
Cyclic Servos 9452s
Radix 690s
Stock Paddles
Stock Tail blades
plus, regarding maximum RPM , are my calculations correct?
12S x 3.7v = 44.4v
44.4v x 560kv = 24,864rpm/v
24.864 x (14T / 164T) = 2122rpm
2122rpm x 0.8 (efficiency) = 1698rpm (approx 1700rpm)
if so, isn't that alittle low for 3D ..etc ?
R-4-L is offline        Reply With Quote
Old 04-11-2009, 09:21 AM   #18
QYT001
12S x 3.7v = 44.4v
The formulae:
motor kV * 3,7V * S battery * T (Motor Pinion) / T (Main Drive Gear) * Efficiency coefficient (0.9) = RPM
So,
1/ 560 Kv x 3,7 V x 12S x 0.9 = 22377,6 rpm
The Rotor Head speed of T-Rex 700 is designed for 1950
The Main Drive Gear is 164T
2/ For 1950:
22377,6 rpm / 1950 = 11,475692307692307692307692307692 (ratio of reduction)
164T / 11,475692307692307692307692307692 = 14,29 T = ~14T (Motor pinion)
It looks OK.
The question: what RPMs are for 3D?
Old 04-12-2009, 07:28 AM   #19
R-4-L
yea , I have no idea why I chose 0.8 as the efficiency coefficient! I'm sure i read it somewhere.. its does make the difference by 2 tooth.
Thanks for the info, i believe as a 90 size 1800 to 1950 is more than enough for 3D
Old 04-16-2009, 12:51 PM   #20
aliboy
Anyone have any experience of running the 4035-560 with a CC 85HV on 12s? I already have one and would like to avoid the extra expense of going to the 110. I've seen some graphs showing generally low current, but spikes to the 90's. Any opinions? Thanks,
Al.
aliboy is offline        Reply With Quote
