Go Back   HeliFreak > R/C Helicopter Support > JR Helicopters
JR Helicopters JR Forza, Vibe and Vigor Helicopters Discussion
Old 03-25-2009, 07:55 PM   #1
KillerKanopies
Default Clutch question?
Is is me or is the Vibe 50's clutch really tight. I have to hold on tight when starting because it wants to go. Even at a really low idle it's grabbing. Makes it tricky to handle. I've got over 20 flights on it and there's no sign of wearing in. Do I need a new clutch?
Adam Q
-Killer Kanopies-
KillerKanopies is offline        Reply With Quote
Old 03-25-2009, 08:19 PM   #2
onequick96gt
The clutch on my Vibe 50 does seem to engage at a little lower rpm then most other brand 50's I have been around. Nothing wrong with mine after 62 flights though.
Aaron Johnson
Synergy/Botos Design and Distribution
YS Engines/Hatori
Byron Rotor Rage
onequick96gt is offline        Reply With Quote
Old 03-25-2009, 08:43 PM   #3
Helico-pteron
Mine too, lower your idle.
Helico-pteron is offline        Reply With Quote
Old 03-25-2009, 09:46 PM   #4
KillerKanopies
Much lower and it won't run. I'll just deal with it.
Thanks for the reply fellas.
Adam Q
-Killer Kanopies-
Old 03-25-2009, 10:39 PM   #5
Helico-pteron
Lean out the idle mixture a tad
Old 03-25-2009, 10:40 PM   #6
fiveoboy01
Mine's pretty free. I dont' need to get a firm grip on the head at all or anything.
Make sure your clutch-to-liner gap is even all the way around the circumference of the clutch.
Bill - RWMAA #1009, AMA #805853
fiveoboy01 is offline        Reply With Quote
Old 03-25-2009, 11:42 PM   #7
OverTemp
Mine a lot better since I got the motor broken in and tuned in right. It also seems to do a lot better on warmer days.
1 - Diabolo 1 stuffed with, well, see below
2 - Diabolo 2 stuffed with testosterone, jittery sweat, and rippling flanks
OverTemp is offline        Reply With Quote
Old 03-26-2009, 01:31 AM   #8
rubbersoul
mine got fixed after a hot start
rubbersoul is offline        Reply With Quote
Old 03-26-2009, 05:09 AM   #9
KillerKanopies
I tried one of those too. No luck either.
Adam Q
-Killer Kanopies-
Old 03-26-2009, 05:21 AM   #10
cheech91060
First start of the day mine usually seems tight, then it loosens up. But I think its just because the idle runs a little higher until it warms up.
Frank
HBFP, Trex 450, Vibe 50
cheech91060 is offline        Reply With Quote
Old 05-30-2009, 05:23 PM   #11
rubbersoul
Where can you get a clutch liner for the Vibe 50? Any replacements? I hate to collect bells .
My clutch did not engage today. Killed the engine, restarted and it engaged. Pulled the engine and looks like the gap between the clutch and the liner is too wide already and liner materiall is all over the fan.
Old 05-30-2009, 09:09 PM   #12
richardshakan
It probably was running backwards. I have witnessed it twice in the last 2 visits to my clubs field. I can see it being worn-out if you have 100 gals through it.
JR Vibe 50,Jr Airskipper 50,Sceadu 37,Trex 500esp,Trex 450 Pro,Trex 250,Trex 450XL/Hughs 500D fuse,Beam E4.
JR X9303 2.4 DSM2
richardshakan is offline        Reply With Quote
Old 05-30-2009, 11:00 PM   #13
rubbersoul
forgot about that happening..
but, carrying it to the take-off point I felt the clutch engage as usual and felt and observed the blades going in the correct direction. Spooling up slowly the engine started to quit and I dropped the throttle. Second attempt is when I noticed that the clutch was not engaging. Killed the engine, visual check, then restarted and everything was normal. Hovered for about a minute but decided not to fly it.
Old 05-31-2009, 08:55 AM   #14
richardshakan
Post
Well, with all the work and money into it, i would do an inspection to see what is going on.
Maybe the main nut isn't tight enough on the motor shaft?
Maybe the liner material is defective or has spun?
JR X9303 2.4 DSM2
Old 05-31-2009, 11:55 AM   #15
rubbersoul
I found the JR liner but also ordered the align liner for the 700. Will experiment with my two bells and see which one will last longer.
Old 05-31-2009, 09:08 PM   #16
nargargle
I had the same problem awhile back. I went to spool up and the cluch wasn't grabbing properly. I pulled the engine and cleaned the cluch liner and shoes with alcohol. It solved the problem for me. Might be worth looking into. Best of luck.
Hirobo Lepton EX, Kyosho Caliber4, JR Vibe 50, JR Vibe 90SG
Foamy Corsair and Habu, MCX, MCX2, all on JR 11X
nargargle is offline        Reply With Quote
Old 06-01-2009, 10:51 AM   #17
rubbersoul
Will definitely look into doing this before stripping my liner.
I'll wait for the new liner to arrive and compare thickness and decide if it is time to replace it or just clean as you suggested.
Thanks.
