| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Hey guys,
Well I seem to be having an issue I can not solve and need your help. Recently I purchased a couple zippys from hobby king along with a new charger, the GT-A6 with the 6 cell adapter so I can charge 2 batts at once. Well recently it seems the rpms on my 400 while hovering are goign up and down, probably an indication of bad battery packs? It does not do it on my new zippys (yet) but has started to do it on all 4 of my eflite packs. The only other upgrades I have done recently is a align 6v 35x esc and aluminum tail. Could my new charger be killing all my batteries somehow? I hope I am not doing something wrong. My charger if set to balance always takes 120 mins, whether its one pack or two..... I don't know, but hopefully all my packs are not dying at once...kinda weird eh? Thanks for any help, |
How far are you discharging them? Should stop after 6 mins or so of flying.. .or better yet to 80% discharge...that's a real common cause of dead lipos. That.. and storing them fully charged more than a couple days!
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
I don't think I discharge them too much. I normally only fly 4-5 mins/pack. Normally they check out at 3.8v/cell when done.
Could it be my new charger do you think? |
I forgot to mention, it does this immediately even when the pack is fully charged.
So is it ONLY doing this with the new zippy's or all battery packs you have? If it's all, then I would start by ensuring your throttle signal itself was good, and connections to the RX are good. If those are functioning properly, I'd look into the ESC next. Does it do it on the ground, or just loaded in the air?
Blade mCX / mCPx / 130X / B400 HS-65MGs FBL CopterX w/3400g CCBEC 440H B400 HG-5000 w/5083, CNC Head, HS-65HBs / B400 GY401 w/3400g, JR285s T-Rex 600E / 600N Pro |
#6 |
Oh yeah... if the ESC is getting really hot.. you lose power... feel it after it stops and see if it is too hot to touch. Can you spin the main rotors pretty freely? They should spin at least 3 maybe even over 4 times before they stop when spun fast by your finger.
#7 |
I have 4 old eflights (1yr) and 2 new zippys. It only started off doing it on 1 of the eflights, and is now doing it on all 4. The zippys have not started yet, but they have so much juice I am wondering if I am just not noticing it yet.
ESC is only warm, so I am pretty sure thats not it. Could my new charger be overcharging the cells? It seems cell3 is lower on all of my packs when charged. Man, what a frustrating problem. |
#8 |
How many cycles do you have on your eflite packs?
#9 |
not sure, I might guess 100 times approx. I have used them for about 1.5 years. I don't expect a lot more life.....but them all dying at once makes me wonder about the charger...
#10 | |
My 1800 eflight pack had a cell go bad so I desoldered the bad cell and made a 2S receiver pack out of it. The 2200 lost its punch so now it just runs my nitro starter.
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0 Last edited by Penguin; 03-30-2009 at 03:30 PM.. |
#11 |
Yes, you may be right. Is there anyway to tell if it is my new charger?
would balancing for 2 hours hurt the cells in anyway? |
#12 |
From what I have read the slower you can balance and charge a pack the better off it will be. Can you read MAH remaining in your pack? You say voltage is 3.8 per cell, what is it after a charge does it come up to 4.2 per cell? If you have gotten over a hundred charges on your eflites you are doing great. Most dont last half that long. I have about 80 charges on my one eflite and it shows signs of not being as strong as all my zippy's What size are your zippys? are they 2200mah? Do what was suggested earlier on this tread and check every thing for the right tension, mesh etc.
Blade 400, 2221-18 Gp750 gyro, CopterX tail, head TREX 500 ESP,JR770G,DS890G. Trex 450 Pro. HS65MG with GP750 DS520 ,HS65HB,DS290G |
#13 |
thanks for the help guys, I will check it out tonight after work
#14 | |
What amps are you charging at? I noticed that when I use the 2x3S to 6S adapter with my Accucel 6, it takes a good bit longer for the final balance. How long does it take to complete the charge when you charge one 3S at a time?
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0 |
#15 |
5 amps with adapter. Measure the voltages and match two as close as you can.. otherwise it works.. but takes a LONG time at the end to balance.
#16 | |
| Blade 400 | Trex 500 Landing Gear | HXT900 | HGD 201HB | Blade CX2 | Sim - G4 | |500 ESP - under construction| |
#17 |
I am charging the elights @ 1.8 amps 3cell 11.1 volts,
When I have 2 at the same time, same amps, I just doule the volts for 6 cell. 22.??V It takes 120 minutes for 2 batteries, and the same for one, if I balance. If I fast charge it does it in 30 mins. It charges 2 cells to about 4.15 volts, and the 3rd cell is always a little lower, like 3.8. Its weird, beacause when I got my new zippies all the cells were bang on 4.20 volts/cell, and after a couple charges teh 3rd cell is lower than the rest. Don;t know if that is normal or my charger. |
#18 |
I'd say your charger has issues. My accucell always charges all of my batteries to 4.19 to 4.20V/cell except my eflight 1800 with the bad cell. Do you have a buddy with a good charger who can test charge your batteries and compare final cell voltage and time to charge.
#19 |
Hey Guys,
I am still having troubles. Maybe I should take a trip to the LHS. I charged up an old eflite battery and a new zippy. Just to compare batteriesto see if that was my issue. Well, looks like both batteries are doing the same thing. I just notice it more on the eflites bacause they are slightly older. Right after I lift off into a hover it sounds like teh rpms drop a little and there is a different noise to it. Not a mechanical noise. but more like a voltage drop or something weird like that. I really am stuck on this one. Could it be the new align esc I put on? I checked the blades, and they spin freely and belt is adjusted near perfect. Can;t think of anything else.... Jer |
