| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Just asking how much give should there be if any on the blade 400 feathering shaft? As in how much can you move it via the main blade grips?
Jez To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - Discussion forum about relationships, health, living, university and life in general. Built up from the remnants of the BBC One Life sunday surgery site, we exchange information and advice on topics that matter to you! |
you should have 4 shims and 1 step washer per side
Crashs come easy Patience does`nt To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. retired the 3 year old blade400
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
People say 4 but some say 2.. I don't get it really. What is the difference having 4 or 2? (each site that is)
Also how much play should there be?
4 shims and 1 step washer, play will not be an issue
#6 |
It is a matter of preference/experience really. As you add shims it will make the head tighter, make for more responsive collective responces. This comes in very handy {for me} when attempting manuvers that require crisp/accurate inputs for collective. The less shims will make the more mushy for a less demanding collective input. Less shims, more forgiving for novice pilot with little stick time.
#7 |
So as I have still yet to be doing full laps as it were 2 maybe the best?
#8 |
Exactly.
Jez, the best advice I can give you is try each combination - two, three and four each side - and see which YOU prefer. It's all pretty much down to how you feel with the heli. It's a 5 - 10 minute job to change it out if your careful so experiment.
- EF Blade 400 - HS65mg/DS760/DS8910/440H/HW40/SAB325/3s/10t - Flight Log: 308 - - MSH Protôs Carbon - HS-5245mg/DS760/DS650/SportBEC/MSH26-10/Jeti80/SAB425/6s/13t - Flight Log: 76 -
- BUILDING! - MSH Mini Protôs Carbon - HS65mg/Quark/DS8910/Scorpion/YGE/SAB325/3s/16t - Flight Log: 0 - - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. - |
#9 |
push and pull straight out on the grips. if you feel looseness you need more shims. after that play is gone its just a matter of preferance on how tight you want it.
The tighter it is the more responsive it will be
TREX700LE-beastx,TREX 600LE-vbar,COMPASS 6HV-beastx,
#10 |
I just feel mine has quite a far bit of play which made me wonder. I have 2 each site and don't want it to become to twitchy with more as Im still new. But if some people have 2 I would guess theres would have more play as well then?
#11 |
My blade had 4 shims per side out of the box. the stock plastic head is always going to have some play in it.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. MCX, CX2, MSR Blade 400, 500ESP, 500CF
