| Belt CP E-Sky Belt CP |
Hey guys,
Do the HS-65HBs work with the stock receiver in a Belt CP V2? What other servos would you recommend? Thanks. |
They should work fine with the stock receiver just may need reversing. The HS5's are excellent servos especially the MG's.
T-Rex 500 µBeast, 450 Pro (soon to be µBeast) & a Compass 6HV To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. And a P51D plank......SSssssshhhhhhh! BMFA & RCHA Member [B][COLOR="Blue"] |
Do I need a special tail servo to work with the HH gyro or a HS-65HB/MG would be just fine?
What gyro you got?
Happy Heli-days !!!!!!!! Skip To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. T-Rex 450Sport, T-Rex 600NSP, OS50, DS610s GY401/S9254, KO Propo PDS2364,KBDDs, Align 600Ds, MultiGov Pro DX7/AR7000, Phoenix +DX6i Blade mSR |
The stock one for now. Maybe the GY401 in the future... Thanks.
#6 |
My new Belt CP V2 just arrived today. I had time only to charge the battery and check how the servos and gyro work. Everything seems alright so far, except that I can hear strange noise from 2 of the servos even when I'm not giving any stick input. Any ideas what this is happening?
Thanks. |
#7 |
Is it a whining scrunchie noise?
I wouldn't worry about it. All my servos do it.. It's normal from my expereince. Typically it can be from the servos trying to pull and push to be in a position and they can't due to binding or they are just being.... well the way they are.. ![]() |
#8 | |
#9 |
I wouldn't think so...
Though if they ARE binding - you may wanna see if the heli is put together properly and everything moves correctly. Could result in a crash or poorly flying heli - maybe even the gears stripping from the excessive force put on them always trying to turn but unable too. But if they do it just for the sake of doing it - don't worry. All my Servos have done this noise thing, even when I'm at midstick. From my SG90's to my Esky's. |
#10 | |
#11 |
The tail servo is an easy fix.
- Turn on your TX, make sure your throttle and idle up is OFF - Plug in your heli - Leave it until the gyro is set and stopped twinkling - Then unscrew the horn off the tail servo, and position the horn at 90* and screw it back on. The servo always goes so it'll fit at 90*. At least it always has for me! The servos in the Cyclic commonly make the noise. But just to be sure, disconnect your motor (only need to take off 2 wires but take off all 3 just for a safe measure). Turn the idle up on and put your throttle at mid-stick, make sure the cylics horns are as close to 90* as possible. If you browse around you'll see lots of detail with pictures on proper setup but just for now see if the horns sit at 90 and not some far out of whack position. They'll be a good indication if they are binding or not. |
#12 |
#13 |
A little word of caution!, whenever you are making any kind of adjustments with the heli plugged in, be sure to UNPLUG your motor wires!, you wont believe how dangerous these things can be......
Raptor 30 V2,Raptor 50 Titan SE, Caliber 30.,Esky Honey Bee King V1,Esky Belt CPX,Eflite Blade MSR, Jr 8103, Spektrum Module, Spektrum DX6.... |
#14 |
There will be servo reverses on your TX. =)
You may be able to correct the direction by flipping the servo around though. |
#15 |
Do the hitec 65HBs fit on the cyclic in the Belt CP V2? Thanks.
#16 |
I would say YES, but not having had a close look at a V2, I may be out of order. However, guys use them on the V1 and I cannot imagine that the particulars of the cyclic servos and the frame mounts have changed much from the V1 to the V2.
Anyone else clear this up for definite??? Skip
#17 |
#18 | |
With a DTS mod or T-Rex style frame, yes - you can swap them around and make it work, but not with the stock frame and transmitter.
Mika T-Rex 600NP, T-Rex 500 ESP, HDX500 SE V2, HDX450 SE V3, T-Rex/Outrage SE V2, EXI450, T-Rex 250, CopterX/Guru-Z hybrid, HBFP separates, Lama V4, 2 x Walkera 4#3B |
#19 | |
-Heli Yea! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Master of: the living room, stockTx, mechanical setup and, the obvious! Belt'ish CP MG90's,704A/S3114,CX head,HDX3550/Align 35G/HDX 500 SAH:-) HS-82MG's,G401B/BMS-631MG,HDX850/Align 60G,6s lipo /Hirobo Shuttle ZX .30 /Walkera 4#3B/Falcon40/Lama V3 DX6iThank you kind gents! :-) |
| Tags |
| belt cp v2, servos |
