OK.. cycling my new 3300's a couple of times... "Lipo storage" wants to go down to 3.8V/cell and "Lipo Dishcharge" wants to go down to 3.0V/cell.
Isn't 3.0V too low? Or is that considered an empty Lipo (but still safe)
It's not just a hobby... it's a lifestyle! Outrage Fusion & 550 / Goblin 700 / SK540 / Kontronik / DX8 / Quantum / RJX / 4010 Duo Pete Team Outrage. |
3.0 V / cell would be an overdischarge. I would not want to go lower than the nominal voltage of the cell ( 3.7 V ).
Keep a close eye on those Turnigy's. |
Thanks UV Sounds like a plan. I'll stop them at 3.7v and charge to full again. I wonder how many cycles I should do before flying the new lipos? Anyone?
EDIT: I keep forgetting there is a battery forum on helifreaks.. I best be off there.. no doubt all these questions are common.
Why don't you cycle them with some short easy flights?
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0 |
thats what i want to do, in normal mode with throttle at like 50 just hover for a few minutes for the first few cycles.....would that be ok?
Thanks, Daniel
Daniel DX7 - Mode 1 TREX 450 PRO!! - GP750 & DS520 - HS65's - AR6100 - Scorpion -8, Align speedy |
#6 |
#7 |
Sounds good. I'll just cycle all 4 lipos just one time.. and then do some easy flying for a few minutes each... so I can at least some flight time on their 2nd cycle.
#8 |
What? 3.7v? I don't think that sounds right. Isn't 3.2v more of a safe low limit for LiPos? 3.0v is borderline.
#9 |
I don't know. I just know I always fly until the resting voltage is 3.8V per cell.. maybe 3.7V.
I bought one of these... this should help.. friends got one and it's REALLY cool. http://www.hobbycity.com/hobbycity/s...idProduct=6232
#10 |
They make smaller similar units like the blinky balancer which essencially do the same thing. but for about 30 bucks, you get a reading to the 100th decimal, unlike to the thousands like this one.
Trex 500 Esp, CC Ice 75, Hyperion 1600kv, Gp750, Ds510's , Ar6200, DS650 tail mod. DX7 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hyperion 250w 6s Charger, Hyperion G3 Battaries ParkZone T-28 w/ custom flaps+retracts, Ar7000 6s RCLander F-16 - To scared to maiden |
#11 |
as far a s i know it is safe to discharge to 3v,if the charger is accurate it should not be a problem.
have not heared abut any lipo that would get damaged with a discharge to max 3v or charged to max 4.2 |
#12 | |
i use them in all my helis. still fly with timer but some times when i fly harder then normal it is a grate insurance not to drain the pack to much |
#13 |
3.0 to 3.2 v/c is basically the standard for MAX safe discharge of a lipo. I never run mine below 3.7v/c when flying. To cycle them, I fly mild flights and cut my timer in half. Usually 2.5 to 2.75 min. and cycle 5 times, then let it rip. That's about what I have read over the years, with slight variations, but I have never had any problems with my lipos either. Hope you enjoy the 500, know you will.
Sponsored by Visa/MasterCard / Team Budweiser / Trojan Field Rep Donut Connoisseur To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. HELI-FREAK, You couldn't have picked a better place to land ! |
#14 |
I think 50% power would be too little for safe hovering. My buddy Nate had a great idea for breaking in new packs. He suggested setting a throttle curve for 50% at midstick and just let it sit on the ground for 5 to 10 minutes depending upon how much you want to discharge it.
An option would be to throw the packs in a plane and do some leisurely flying for about 10 minutes. I didn't have the patience to do either, I just threw the packs on the heli and went for it. Granted I'm using $18 Zippy's. If I spent $80 per battery I'd probably break them in properly.
Warp 360 Spartan Vortex VX1 |
