| 700 Aftermarket Upgrades Align T-REX 700 Aftermarket Upgrades by HF Vendors and Supporters |
#41 | |
There is no way I would suggest that you miss out on this great and affordable heli over this issue. I hope that this is helpful for putting things into perspective.
Have laser, will travel. |
#42 | |
Fin, you can probably throw the -1 gear in yours and be good to go. ![]()
Album To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Trex 700E & N, Stratus, Atom, Knight 3D, Vibe 50, & Protos. RREMODELS.COM, Magnum Fuel, KBDD intl Products To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#43 |
So when are we going to hear more about this FA Designs gear.
I want the black one... It's been two weeks Finless! Let's get on it huh...!
Jesse T700N FBL - V-Bar w/ 3DX Head T250 Super Pro - HS-5084MG Tail Servo X9303 |
#44 |
Bump for an update????
#45 |
Yeah I would like to know of anyone using these Mod1 Microheli gears. I was tempted but after their disasterous attemp at the Mod .7 i decided to hold off.
Just put a -1 main gear on mine though and the mesh is perfect. |
#46 |
I running one in both my 700n and my 700e. The tooth shape on the plastic gear is not ideal and is a little rough feeling at first but they wear in very nicely. I'm using a Mod1.0 11 tooth pinion on my electric.
#47 |
guys who has stock of this mod 1 gear for the trex ? which tooth count on main gear and pinion do I get to keep it the same as the stock gear ratios ? Im buying stuff already from readyheli but i cant seem to find the gears there ...
#48 |
cbdane,
What headspeed do you get at 85% governed for the Microheli 1.0M gear and 11 tooth pinion? I'm ordering the exact same setup. Thanks in advance. |
#49 |
I just installed the Micro Heli MOD 1 main Gear. I have about 1 to 2 mm vertical play between both gears.(main and autorotation) Is this normal.? Is there an install video?
#50 |
And I just bought the gear set and the pinion gear threads are not the same as the clutch bell or the nuts so its useless I'm sending them back
#51 |
Add me to the club. Stripped my main gear yesterday. I've seen the Align upgrade as 'coming soon' on readyheli for weeks now......
WWBD? |
#52 | |
Just another crappy day in Paradise.... Aloha! |
#53 |
ya but only the main gear (115t). if i run that with the stock 20t pinion i'd have to run a 2600 headspeed to to stay in the powerband of the engine.
WWBD? |
#54 |
They carry the MicroHeli set, which is probably better anyway.
http://www.grandrc.com/inc/sdetail/195457 The align main gear is probably molded. The MicroHeli gear is CNC delrin.
#55 |
I bought the Micro Heli Gear set and the pinion would not screw into the stock clutch bell nor would the nut screw on the gear threads were not the same. I returned them and Heli Direct said it would work on there 700bell
#56 |
Where can I buy the FA Design upgrade?
#57 | |
I have the same problem .After I disassembled everything I noticed that one bearing was not loctite.I just put a bit of green loctite and now the vertical play is a bit less. ![]() ![]() ![]() |
