Old 04-12-2009, 08:20 AM   #21
mjm0505
Here is mine flying.
TREX 600 Nitro Pro
TREX 500 ESP
Blade MCX
mjm0505 is offline        Reply With Quote
Old 04-12-2009, 08:21 AM   #22
mjm0505
Deleted...
TREX 600 Nitro Pro
TREX 500 ESP
Blade MCX
Old 04-15-2009, 11:01 PM   #23
deesee
Looks like i might have to upgrade mine to 6s
deesee is offline        Reply With Quote
Old 04-16-2009, 01:34 PM   #24
pitounet
The question is Why 6s. I think 6s is too much. 4s is plenty for a 450 class heli (no matter what kind of flying you have). I have been flying for two years a Trex 450 se + jazz + neu 1107/2y with 2100 prolite/Align 2100 16c 4s (180-190g pack). I've got a 5-6 minute flight while respecting the 80% rule, nothing is hot, I can fly continuously. My pack last more than 2years and WAYYYY more than 100 cycles.
Here is a flight with one of my old packs (between 150 and 200 flights on it)
http://vimeo.com/3799582
pitounet is offline        Reply With Quote
Old 04-16-2009, 01:38 PM   #25
ChrisH
pitounet until you've flown a 6S 450 you wouldn't understand ...
I'll leave it at that since there's no need to hijack this thread, there are many others about 6S setups in 450s.
For vimeo videos you only need the clip ID which is the series of numbers.
Code: [ V V ] 3799582 [ / V V ] (omit the spaces)
Result:
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is online now        Reply With Quote
Old 04-16-2009, 08:57 PM   #26
nitrouspete
Default My 450 PRO
Hi Guys,
Here is my 450PRO. Built with Spektrum AR7000 recv, JR287MG cyclic servos, JR3500G rudder servo, JR7703D gyro, CCBEC.
Very, very tight fit. I will have to re-wire for a cleaner look for sure now that my test flying has been done. Took long to make everything fit but the reward is having it fly.
Also testing with shorter tail blades...
Very cool machine...
ID:	92190   Click image for larger version
nitrouspete is offline        Reply With Quote
Old 04-17-2009, 08:14 AM   #27
Jimmy!
Originally Posted by nitrouspete View Post
Hi Guys,
Looks good! Is that a heat sink on your motor there? From what I hear about that motor gettin hot, that seems like a really good idea.
Jimmy! is offline        Reply With Quote
Old 04-19-2009, 12:31 PM   #28
toyturbo
Cool
Here's pics of my new Trex 450 Pro.... Enjoy!
toyturbo is offline        Reply With Quote
Old 04-21-2009, 02:44 PM   #29
kenny.c
HI there
Ive just finished my pro build......and as other have said.....it a VERY solid heli and goes together very easy......however the wiring is a nightmare........
Managed a couple of packs through it today......on the second pack went for some inverted flight (which is brave for me at test flight stage) the pro is VERY stable and very powerfull....similar to a trex500 with a decent lipo on it. It makes a great noise aswell...bit like a real angry wasp ....
The tail combo of algin gyro and align DS520 servo is totally locked in.......doesnt even twitch when doing hard collective moves like tic-tocs......
Fly safe
Ken
kenny.c is offline        Reply With Quote
Old 04-22-2009, 01:52 PM   #30
Scotty T
Addicted to Helis
Trex 900 DFC Ultra Combo OS HZ 195 Hyper , Goblin 1200 84S Flybared
Scotty T is offline        Reply With Quote
Old 04-23-2009, 01:32 PM   #31
dr_cheeks
Default 450 pro pics
Finaly Got It Done :-)
ID:	93444   Click image for larger version
ID:	93445   Click image for larger version
ID:	93446   Click image for larger version
dr_cheeks is offline        Reply With Quote
Old 04-23-2009, 09:55 PM   #32
ForceFedDSM
dr_cheeks, I highly recommend strapping your gyro with some velcro. A local pilot came in to land his 500 after a flight and when he was 2 feet from the pad his gyro tape came loose and his gyro was hanging. You can imagine what happened next, and it wasn't even when he was flying and taking chances, that hurt to watch. I bought some straps that day ans strapped the rest of my gyros.
ForceFedDSM is offline        Reply With Quote
Old 04-25-2009, 08:56 PM   #33
emilware
I got it yesterday. so here it is.
T-REX 700E FBL 3G ICE HV 160 , T-REX 500 ESP FBL 3G , T-REX 450 PRO ,JR VENTURE CP30
emilware is offline        Reply With Quote
Old 04-26-2009, 10:09 PM   #34
ken22golf
Here's my new heli. Just about drove it in the ground today on its third flight...
Anyway, as you can see, I didn't use any of the original electronics other than the gyro. Specs are in my signature.
The heli is pretty much unboggable and more stable than my V2. Wiring sure was a PITA...
8S Trex 500 ESP, Jazz 55-10-32 / 3026-1000 (Neu 1706/2Y ordered), 3517 cyclics, Spartan w/ 3500G, 425D, 7C FASST
ken22golf is offline        Reply With Quote
Old 04-27-2009, 03:36 AM   #35
mahbouni
Originally Posted by JRC4 View Post
Cool little heli
Attachment 90863
Attachment 90862
Outrage 1300 6s,Jazz 40,HS-5065,Scorpion 1630,13t,DS3500G,AR6250,CC 10 amp bec,CY paddle blades,
lOTS OFF POP!
Though it was great stock!
If you think that is fast then try a couple of ThunderPower ProPower 3s 1350mAh packs in series. In my Rave with 350mm blades and the same 2221-1630 motor I get no less than 3200rpm on a full collective punchout, peaking at 689W. With an AUW of 925g, my power to weight ratio is more 740W/Kg.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 04-28-2009, 04:24 AM   #36
OICU812
This is getting boring, someone get some custom canopies in this house !!
OICU812 is offline        Reply With Quote
Old 04-28-2009, 10:47 AM   #37
ken22golf
That's why I didn't even post a picture with the canopy on...
Old 04-28-2009, 05:21 PM   #38
NotEnoughTime
Got a Fusuno canopy......stock is better.
NotEnoughTime is offline        Reply With Quote
Old 04-29-2009, 01:23 AM   #39
caotri
Hi alls,
Here is my with 6S config outrage motor, 350 baldes.
Regards
caotri
ID:	94483   Click image for larger version
ID:	94484   Click image for larger version
ID:	94485   Click image for larger version
Logo 500-610Blades:BLS252/V-BAR-9254/Z50A-600 -Jive80HV/ NanoTech 10S4000mAh + Quadrotor
History: Lama V3, ESKY CP2,,BeltCP, T450V2, Gl500, HDX500, Hurrican 550, T600E, T450Pro, Logo500SE, ... more to come
caotri is offline        Reply With Quote
Old 05-06-2009, 08:12 AM   #40
mahbouni
Nice one! Where did you get those tail servo mounts? How did you extend the TT and where did you get the boom from?
