| Blade 400 Blade Helicopters (eFlite) 400 Helicopters |
Still working on my hovering in the parking garage yesterday, I was about 4 mins into my first battery. I am really starting to feel like I'm getting the hang of tail in and I'm working towards side in hovering. Suddenly, the heli piros out of control. Luckily, I managed to land her safely...having the training gear helped me there! Checking the heli over, I notice that the tail servo is not moving and the gyro light is not on. I unplug the gyro and put the servo plug into the receiver. Servo checks out ok. Try the gyro again, I get no response. So, I guess the gyro really did die on me. I'm thinking of replacing it with the G401B. I know there are a few others out there that use this bargain gyro and seem to like it. Does anyone know if the Spektrum DSP75 digital tail servo is compatible with it? Also, I plan to return the stock gyro...hopefully Horizon will send me a replacement too.
Replacement Blade 400 for stolen heli To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. : HB400 Stock motor,CC25,HS56's,DS12GCP tail,GY240, Carbon fiber blades. Still needs Tx/Rx to Fly :o www.twitter.com/britontour |
Sorry to hear that about your gyro. The 401 is a good choice IMO.
Unfortunatly, you'll find yourself replacing a lot of stuff on the B400. I think the only electronic parts left on mine is the receiver and battery. I chose to put all the alumium parts on as well, but that was by choice, not need. Replacements are not a bad thing however. Every replacement improves the B400. It's not a bad heli at all. Very good starter system. It would be nice if they used better parts, but if they did, you wouldn't be able to get a full RTF for $500 us.
Blade 400 3D Beam E4 Shocker 30 TRex 700N MCX, CX2, DX7 |
At first I didn't think the 401b was that much better than the 110, but I recently purchased another heli and used the 110 in that and flew the two one after the other and couldn't believe the difference! A good CHEAP upgrade IMO. Hope it helps and good luck.
#4 | |
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blade 400 X 8, CopterX CF SE V2 EXI-450, Clone CF V2 Pro DX6 X 2, DX6i X 4 Need one? DX7 X1 not in use, it's CRAP! |
I am waiting to recieve the latest tellebee gyro from hobbyking
$33 once recieved will set it up and let you all know how it goes had stock gyro for a year but to many crashes probably stuffed it up same problems you had. |
#6 |
The G401B is ordered and hopefully on its way now. I saw a nice looking canopy on CNC's site so I ended up buying that too!! I thought it was appropriate for me. I just need to get the TREX500 mounting posts from my LHS to make it fit.
#7 |
Don't forget Horizon hobby will replace your failed gyro for free. Can't hurt to have a back-up gyro even if it is poor quality.
#8 |
I contacted Horizon through their website about a warranty replacement, but I havent heaard back from them yet. Maybe I should just give them a call instead.
#9 |
The Gyro and canopy arrived today. Can't wait to get the gyro installed and see how it handles compared to the stock unit.
Canopy will have to wait a while before I can install it. Check out the attached picture. Hopefully, CNCHelicopter will replace it free of charge.
#10 |
Yeah, just got a reply from Jeff at CNCHelicopter. Says he's going to send out a replacement canopy. Sweet!!
#11 | |
well atleast you can use the canopy dureing practice flights, that way if you crash you wont tear up a good canopy so thats the g401b gyro? you might look over on rcgroups, they have a hole thread on this gyro
Crashs come easy Patience does`nt To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. retired the 3 year old blade400
#12 |
I thought of that. Popped the dent out...Canopy is split top and bottom. If I was going to use it for practice, I'd have to do some repair work on it or it would likely split in two and fly off while hovering. Any recommendations for repairing fiberglass? I'm assuming I just need some fiberglass cloth and epoxy maybe from a car parts store?
#13 |
thats probaly the best way to fix it.
or if you have something like that mesh you get in the sheetrock repair kits and some super glue? dont know if that`ll work but its a thought. maybe some thin cloth and super glue? the fiber glass repair kit from a parts house like you said might be the strongest repair
#14 | |
I have repaired MANY canopies, best used on tears. Best thing is it stays flexible while holding like crazy..just coat a thin layer inside. For splits (cheapest canopy design ever...epoxy on top of paint) just mix up some 5 min epoxy and give that a shot.. to reinforce, use a coat of goo for added strength. Good luck! PS Based on really bad (intensional?) design of stock canopy, I'm giong to invest 15$ or so for the same canopy you bought...They seem to withstand even hard hits on pavement from the reviews I have read. |
