Old 04-12-2009, 10:40 AM   #1
rcflyers
Default BEC or not???
I have the stock Align ESC in my 500, I have heard they are not that great.
Should I fit an external BEC?
If so, how many amps?
Thanks.
rcflyers is offline        Reply With Quote
Old 04-12-2009, 10:47 AM   #2
Russell Bear
The stock ESC and BEC works fine, run it...
Russell Bear is offline        Reply With Quote
Old 04-12-2009, 12:34 PM   #3
Shef
I installed a SportBEC...works like a champ. $30 insurance policy. I'm sure there's a bunch of others that you can use too.
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 600ESP V-Bar, 700E 3G
T-Rex: 550 DFC
Shef is offline        Reply With Quote
Old 04-12-2009, 04:37 PM   #4
Gregor99
SportBEC here as well. There are too many brownout related issues with running a built-in BEC. Seems like most ESC vendors, not just Align, cut corners on the BEC to keep overall ESC cost down. So you end up with your heli acting weird or falling out of the sky
I'm glad to see HobbyWing and CC now offering thier ESCs without BECs. That forces you do to the right thing. Now if we could just get all servo vendors to publish real current draw values. That would give the user the right information to properly size the BEC.
Hitec does publish thier current draw values, but when I've tested them, the numbers are total fiction. My results are almost double what Hitec reported. I emailled Futaba about the 9560, 9257, 9452 and 9254. They reported that each servo draws between 1 and 2 amps. If that is true, we need BECs that are rated between 4 and 8 amps. I need to test my Futaba servos and see what they are actually drawing. I'm guessing typical heli use won't approach 2 amps. But even its only 1 amp, the we need a 4 amp BEC to run all 4 servos at the same time.
Greg
______________________________________________
Synergy E7 - Compass 600e - T500 - Trex Pro - mCPX
Gregor99 is online now        Reply With Quote
Old 04-12-2009, 06:13 PM   #5
eightythree
but then again printed info on the rating of a bec is probably under what it can actually take..
i think the stock bec will be fine. i just setup my 500 and im weary about it, but im sick of wiring in becs and when i can get away without it ill chance it. theres also the same chances of an external bec failing also...
are there many reports of stock becs failing? or with this just early on?
eightythree is offline        Reply With Quote
Old 04-12-2009, 08:42 PM   #6
Shef
Gregor - so does the SportBEC provide enough juice at 3.5 amps? I've never had a problem w/ it, but it's an interesting question.
T-Rex: 550 DFC
Old 04-12-2009, 10:54 PM   #7
Redfire SVT
A BEC is insurance for me too.
http://www.hobbycity.com/hobbycity/s...BEC_for_Lipoly
Redfire SVT is offline        Reply With Quote
Old 04-12-2009, 11:04 PM   #8
Gregor99
The SportBEC is working fine. But I'm still need to take the current draw measurements to see how close to 3.5 my setup is drawing. Been busy with other stuff but will get too it soon.
Greg
Old 04-12-2009, 11:07 PM   #9
JaggedEdge
I have a servosense on my flybarless 550 with CC80/SportBEC/9650's/SK360/401/9254.
In FFF flight the heli would porpoise no matter what I did with the SK360 and the Servosense read max 2.5A current draw. Replaced the SportBEC with a 5A Hercules and no more porpoising in FFF.
On a 500 you should be fine with the SportBEC unless you're drawing lots of current with a 8V/flybarless setup.
-TREX600NSP - TREX500ESP -
917540 -
1003 -
JaggedEdge is offline        Reply With Quote
