Old 04-15-2009, 12:44 PM   #1
Airjunkie
Default if i buy a zippy 6s 5000
Should i pick up this http://www.hobbycity.com/hobbycity/s...idProduct=8331
to connect it to my speed controller so i dont have to resolder?
Will the bullet connectors connect into that blue end? Then the deans will just go together.
Please inform me!
Airjunkie is offline        Reply With Quote
Old 04-15-2009, 01:04 PM   #2
lavi
Dont.
1st, it wont fit zippu's new bullet connector.
2nd, the less connectors you have the better.
bottom line - resolder your connector (I did on all my new zippy packs)
lavi is offline        Reply With Quote
Old 04-15-2009, 01:40 PM   #3
zeenon
airjunkie,
To answer your question you need one of these:
http://www.hobbycity.com/hobbycity/s...ion_set_(1_set)
some wire and a deans connector if you want to go that route. Both connectors on the 5000mah packs are round, not one round and one flat/round, so the blue connectors will not work. I just got 3 Zippy 5000mah last week, cut of the housing with a xacto knife, desoldered the poles, and resoldered deans.
Z
Trex 500 CF (x2) | Trex 600E | Trex 600N (x2) | Trex 700 | Outrage G5 | Trex 250
zeenon is offline        Reply With Quote
