I finally got my 500 in the air but it seems that i am getting some jollts in the tail, i thouht it was my gain so i turned it down, but got the same results, no matter which way i went on the gain it seemed the same, i had a friend look at it, and he told me that there may be an issue with my esc, he pointed out that when i plug the battery in it arms way to fast, and what he meant was that it can spool up even before the 3 beeps come on, i hope i made sense, he also mentioned that the gov in the esc needs to be deactivated and thats why i get the small jolts, can anyone help me.
Hey,
I'm confident your problem is centred around the govenor mode, while it does work it has been found that your better off running the ESC's out of govenor mode and running straight throttle curves. The kicking on the tail your seeing can be caused by the govenor just not quite on the power and hence stumbling alomost to maintain rpm. I would try deactivating the govenor mode and setting throttle curves, just remember that ESC's like to be run above 80% throttle setting for long periods. As an example in normal mode I ramp the throttle curve up very steeply to about the 1/3rd throttle position to get the power in early and before lift off. Here is my throttle readings from my DSX12 for my T500; Normal; 0 ~ 76 ~ 83 ~ 85 ~ 85 (83% being mid stick, 0 degrees pitch) IdleUp1; 92 ~ 95 ~ 100 (95% being mid stick, 0 degrees pitch) IdleUp2; 100 ~ 95 ~ 100 (95% being mid stick, 0 degrees pitch) Hope this helps? .
Ian Contessa Team Robbe SchluterUK / Midland Helicopters / Align To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I agree with coolice,
your problem is caused by the gov mode. The spooli g up before 3 beeps is normal (as long as it is you who order it to spool up). Bottom line, try to turn gov mode off, reconfig your gyro gain and see if it's ok. And about the throtle curves, both the motor and the ESC likes it over 80. If your I to 3D, go with flat 100. Good luck! |
I´m running mine in governor mode. I have lowered my throttle response to medium and I think it´s working fine now.
/ Ola |
thanks guys, problem solved.
#6 |
Some people have noted that the stock gov. can cut out the motor completely in flight. I would be weary if using it.
Trex 500 Esp, CC Ice 75, Hyperion 1600kv, Gp750, Ds510's , Ar6200, DS650 tail mod. DX7 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hyperion 250w 6s Charger, Hyperion G3 Battaries ParkZone T-28 w/ custom flaps+retracts, Ar7000 6s RCLander F-16 - To scared to maiden |
