Old 04-18-2009, 03:25 AM   #1
J.A.C
Default GP750 & DX7 Gain Question
Hi all, nearly completed my little 250 now and have a question regarding gyro gain. It seems that most people are only setting the gain to around 25% and this is where I'm slightly confused. As I understand it the gain for HH (I'm using the gear atv's on my DX7) needs to be at least 50% for it to be in HH mode and less than 50% for rate mode, so surely if I set my gain at 25% ish the gyro would only be functioning in rate mode. Do I set the gain at 75% in HH mode therefore having a 25% gain value?
Any help and clarification on this would be greatly appreciated, thanks.
J.A.C is offline        Reply With Quote
Old 04-18-2009, 03:57 AM   #2
pcliftonjr
...Do I set the gain at 75% in HH mode therefore having a 25% gain value?
Yes. HH mode starts at 50% so that is effectively 0%. So 51% on the radio is 1% gain in HH....then to get to 25% gain the radio will read 75%.
Paul
Trex 600N
Mikado 500 3D, Trex 500
BEAM E4, Mini Titan 325
Trex 250 Super Combo
pcliftonjr is offline        Reply With Quote
Old 04-18-2009, 04:29 AM   #3
J.A.C
Paul
Many thanks for clearing that up, your help is appreciated.
T-Rex 500 ESP
T-Rex 250 Super Combo
Old 04-18-2009, 11:17 AM   #4
Ozz58
This is not how I under stand it.
I aways thought 50% - 100% was HH mode and 0% - 50& rate. Understanding 50% is really gyro off.
So if we are talking 0% to 100% in HH this would equate on the radio as 50% to 100%. So my thinking is 50% is 0% and 100% is 100%. Now doing the math if you wanted 25% gain you would need to set the radio to 62.5%, that would be half of the 25% plus the 50% (or 0% gain) I think if you put 25% gain or 75% reading on the radio you would really have 50% gain.
Guys I could be wrong, this is just how I always looked at it.
Craig
Ozz58 is offline        Reply With Quote
Old 04-18-2009, 11:31 AM   #5
DVS
Hope this helps.
DVS is offline        Reply With Quote
Old 04-18-2009, 11:34 AM   #6
Ozz58
Originally Posted by DVS View Post
Hope this helps.
So I was correct.........could be the first time this year.
Craig
Old 04-18-2009, 11:54 AM   #7
pcliftonjr
Hope this helps.
Where did that come from!? That's a great scale!
Paul
Trex 600N
Old 04-18-2009, 02:35 PM   #8
J.A.C
Hope this helps.
Thanks DVS, is that chart only if you use the gyro sensitivity part of the DX7 though or does it also apply when setting the gain through the atv's?
Thanks again
T-Rex 500 ESP
Old 04-18-2009, 03:24 PM   #9
ryem3
Craig was mostly right. Watch the Finless gyro gain 101 video. I believe the true gain will actually be X-50 times 1.4. For some reason it is not 2X.
Too many helis, too little time.
Spektrum DX8
ryem3 is offline        Reply With Quote
Old 04-18-2009, 03:39 PM   #10
DVS
Thanks again
Sorry I don't know the answer to that.
Old 04-18-2009, 07:49 PM   #11
Firefighternickn
the top row of numbers is what you would use if you're using end points for gyro gain. the bottom is for the gyro sensing menu if you set your gear/aux channel to gyro. It shows corresponding numbers for both.
God made firefighters so cops could have heroes too.
Firefighters: Chicks dig us and cops want to be like us, because we find them hot and leave them wet.
Firefighternickn is offline        Reply With Quote
