Old 04-20-2009, 02:44 AM   #1
keiser BLADE
Default sonix reg cnc tail
i have read about some peoples sonix reg cnc tail not workin so when i got my parts i didnt put mine on , until i seen the hub didnt look straight upon trying to find a vibration, so i gave my sonix tail a shot and the belt does skip a lil, it has a lot less slop than my regular tail, also the reg one the bearings were shot.
ive got to spool it up and bring it into hover inside it seems much better, so im gonna not fly it a whole lot, untill i order the pro tail
later brandon
AMA # 618610
With Christ All Things Are Possible
keiser BLADE is offline        Reply With Quote
Old 04-20-2009, 06:42 AM   #2
pgrange
keiser
I have the regular Sonix tail myself and I really like it. As far as the belt slipping did you swap your belt for a Trex 450 one? I did this with mine and it works like a charm but you also need to mod the tail idler pulley to Trex style also.
Blade 400 Hybrid, Scorpion Commander 35A V2, CopterX Head, Sonix Tail, 65MG Cyclic, GY401+ 5084MG, Sonix Silver Carbon Frame
Standard Blade MCX
pgrange is offline        Reply With Quote
Old 04-20-2009, 10:27 AM   #3
sokal
Originally Posted by pgrange View Post
keiser
if you swap it with a rex one then it will slip on the front pully drive gear
eflite belts have a diffrent tooth spacing than rex
if u wana use the sonic tail shaft you will have to mod the front pully with a rex pully gear
untill i find away to do so i just moded a stock tail gear. works very well
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote
Old 04-20-2009, 10:36 AM   #4
pgrange
Sokal
I didn't make myself clear in the first post. I did mod the front pulley to use a Trex pulley. I simply used some 5 minute Epoxy and glued a Trex 450 pulley onto the standard Blade front shaft. Still holding up after 40 odd flights.
Standard Blade MCX
Old 04-20-2009, 10:44 AM   #5
sokal
Sokal
that was the idea i was going to go with soon.
but i need to find a solid boom about the same length. as the precuts in the stock boom give way and dont allow the tail to get a firm grip. but thats what i like about this hobby its trully a hobby that gets you to build and test thing out.
Old 04-20-2009, 12:19 PM   #6
keiser BLADE
i will try the e flite tailshaft , i know it works for everyone else.
if i can get a hold of my camra i snap some shots,
later brandon
AMA # 618610
Old 04-20-2009, 03:02 PM   #7
sokal
Old 04-20-2009, 04:17 PM   #8
macel
just get yourself the protail and all this is not neccessary more than 30 flights with the protail, original eflite b400 belt and tail pully................ beautifull and i think it does have more steering way than normal hub i run my 401 on 100 % limit and i still have a lil space left, think will try a bigger servo horn next.....
B400,GY 401,FS61bb (8520), 3 x HS65MG, MH gear
Cust B400, cnc body, GY401, Robbe FS61bb(8520), 3xHS 65 MG, MH gear, scorpion 2221-8 VE2, align 35A-GX, sport BEC 6 Volt, SONIX CNC Head + protail, Carbon tail, all carb blades / 5 x outrage 2200, 2 x EF 1800
macel is offline        Reply With Quote
Old 04-20-2009, 07:22 PM   #9
sokal
http://www.cnchelicopter.com/servlet...-pulley/Detail
this is accually all that you need
its the same shaft from the pro tail and will work in the sonic
i was to buy one but the stock tail mod is working very well so far so the next time i bend a shaft will go to this
reason i like the sonic tail is that its black and my bird still looks stock unless your close up on it
dont much like the blue or silver
Old 04-21-2009, 12:41 AM   #10
keiser BLADE
ill order it sokal an see how it works
thanks brandon
AMA # 618610
