Go Back   HeliFreak > For Sale Forums KNOW your buyer/seller ratings! No Price bashing. NO FIREARMS > Electric Helicopters - Only E-Helis
Electric Helicopters - Only E-Helis *No Commercial Ads - E-helis Only
Old 04-21-2009, 12:45 AM   #1
3dz
Default Gaui Hurricane 200 - Ready to Fly plus spares
Hi,
I enjoy flying this heli, but my eyes don't seem to agree, 450 size seems to be the limit for me .... I spent a lot of time, and four or five crashes getting this heli tuned up. I was one of the unlucky that received a kit with difficult to troubleshoot issues.. My main problem turned out to be vibration caused by the stock motor, which is why I have the Z-Power 4850 installed. Once figuring this out, I have since put about 20 or 30 more flights on it without issue.
The heli fly's quite well now, and has a few upgrades.The micro heli tail comes with it, but as you will see on the pictures, I am using the CF hub, I had vibration issues, and was swapping things around, and never got around to putting the MicroHeli tail hub back on. I also have a yellow circle showing the plastic arm on the head, which I used because for some time, no one seemed to have the metal ones in stock...
I've had the heli for just under a year, and would say it has something near 50 flights on it. The DN Power Lipos have the most flights (30), the Outrage and Hyperions have probably about 15-20 total, so roughly 6 flights per battery?
The heli comes ready to fly, with the following components:
1 Gaui Hurricane 200 EP Kit 203910 - ( 299.00 - at time of purcahse)
$ 240.00
LogicTech 2100T Gyro 104.00
JR DS287MG Ultra-Speed Servo 49.99
MicroHeli Tail 59.99
Align 450 Battery Tray 15.00
5x DN Power 850 mah 2S 15/ea 75.00
2x Outrage 800 mah 2S 25C 22/ea 44.00
2x Hyperion 800 mah 2S 20C 25/ea 50.00
Z-Power 4850KV (Installed) 22.00
Z-Power 5150KV (Brand New) 22.00
Futaba T6EX (2.4GHZ) TX/RX 220.00
Align CF 205MM Main Blades 15.00
Hitec HS-45HB Servos (3x) 22.00/ea 66.00
2 xxxxxx Micro Heli Tail Shaft Clamps
2 xxxxxx Micro Heli Tail control tubes
1 xxxxxx Micro Heli Tail ball link and screw
CF Tube Reinforced tail control rod
$ 740.00
Extra/Spare Parts:
1 203211 Linkage Set 3.99
1 203209 Tail boom support set 3.99
1 203189 Long Tail Booms (one new, one used) 2.99
2 832010 Blade Grip Screw Set (10ea) 1.50 x2
1 203130 Tail Rotor Grip (with Hub) set ??
2 203121 High Performance Tail Ouput Shaft (belt Ver) 2.99 x2
1 861901 Tail Rotor Belt 4.99
1 203325 Metal Parts Pack 8.99
1 203540 One Way Bearing - Main Gear Set 7.99
2 203080 Tail Rotor Pack 2.99 x2
2 203120 Tail Ouput Shafts 2.99 x2
3 203222 Long Main Shafts 4.99 x3
1 203240 Flybars Pack 2.99
1 203271 Flange Bearing 4.99
1 203127 Pinion Gear Set 15/9T 2.95
1 803725 Flange Bearing (2 pack with one left) 2.99
1 203231 Mast Collars Pack (L) 1.99
1 203849 Spindle Shart Pack 3.50
1 203625 CNC See-Saw Spindle 3.99
1 203311 Damper Rubbers Pack .99
1 203040 Plastic Head Parts Bag 5.49
1 203070 Tail Gear Case Set (plastic) ??
1 203530 Fin Mounts (partial) 3.49
Plastic blades - a few nicks and cuts on some, but many are usable.
roughly $ 100.00
Note: I cut out the canopy to clear the transmitter when I had it mounted on the side. I've since moved it, but the canopy cut-outs are permanent.
There are also a bunch of other used spare parts, shown in the plastic bin (plastic bin not included), some usable, others with usable parts, etc..
Grand Total Spent: > $1100.00
For Sale: $575.00 Shipped - Continental United States
Thanks for looking ....
ID:	92917   Click image for larger version
ID:	92918   Click image for larger version
ID:	92919   Click image for larger version
ID:	92920   Click image for larger version
ID:	92922   Click image for larger version
ID:	92923   Click image for larger version
ID:	92924   Click image for larger version
ID:	92925   Click image for larger version
3dz is offline        Reply With Quote
Old 04-22-2009, 02:01 PM   #2
3dz
$525 and buyer pays shipping? I'll consider trades for a larger (500 size or greater) heli?
Old 04-24-2009, 03:21 PM   #3
3dz
Default Gaui Hurricane 200 - Ready to Fly plus spares - Sold
Sold .... Thanks!
