| KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum |
Hey Everyone,
One of my favorite upgrades for the TREX 600 electric series is the ability to use the new TREX 700 Nitro main gear for strength and to prevent stripping on high-voltage, high-power setups. Stripping of the stock 600 main gear is a common problem for 10S/12S setups and can be solved with the newly released KDE Direct Main Gear Case Upgrade; thereby allowing hard-3D manuevers with no fear of gear strippage or mid-air failures. Check it out at http://www.kdedirect.com/600ElectricSeriesProducts.html http://www.kdedirect.com/TREX600MGC.html Thanks for everyone's continued support! ![]()
-- KDE Direct, Inc. -- |
Very nice Idea. Are you using a stock 600 one way bearing?
Yes, the hub is designed for the stock 600 one-way clutch bearing. The design is similar to the improved Align versions, in which the entire one-way is supported inside the hub with thick aluminum side-walls, thereby preventing the one-way lock-ups that first plagued the 600. I've had over 200+ flights with this setup and haven't seen a lock-up since.
#4 | |
I ordered one of yours, I will see if it helps ![]() |
Another thing you may want to try is changing the bearing grease used in the one-way. I work with cylindrical clutch bearings at my other job and the proper grease makes a big difference in the performance of a clutch bearing, so it's worth giving it a shot. I've been using the Mobilith SHC 100 synthetic lithium grease (red in color) and haven't had any issues with the one-way. Most automotive stores carry this grease or something similar (I got mine from Pepboys). The one-way bearing grease included in the Align kits is not adequate over the long run for good performance. I've been running my 10S Scorpion motor setup for months now with zero problems.
#6 |
Questition. I went to go grab my 2 spair 700 gears to compair them to my 600 gears. I was going to buy this hub last night as soon as I seen it because I loved the idea of doing this. But before I did, I noticed that your hub mounts the 700 main gear upside down. If you look at the webbing of the gear they are supposed to be in a straight line from the pinion in the oposite direction to take the brunt force of the HV. Just take a 700 and look straight down at it (notice which way it turns) then do the same with the 700 gear on the 600. By flipping the main gear upside down like that isn't it making it weaker then stock? I mean I know you havnt had it strip, but neither have I with the stock gear. (stock gear&4200watts) Knock on wood...450+ flights
I was wondering if it would be possible to machine the hubs flange lower on the hub. I think if you did this, you can put the screws to hold the main gear on from the underside of the gear and then have the gear right side up. Sorry for my crappy explination. I have no programs to draw any diagrams on this computer. Hope you guys understand what I mean. Either way... Great company, great person, great product. Keep up the good work Mr. Keg |
#7 |
So I had to try and come up with a better explination. So I took out the sharpy and note pad
. Below the arrows indicate the direction of rotation, if you were looking straight down at the heli from the top. The dotted lines with pen indicate what I think would be the direction of force. Also took 1 pic from my 700 so you could see the gear on their. Please if the webbing is not a big deal then let me know. As you can see by the 2nd pic the 700 offers ALOT more meat for that pinion so I would love to do this mod. I am just curious about things before I buy.Thanks, My2Cents |
#8 |
I knew what you were saying
#9 |
Hey My2Cents,
I understand what you are saying and you brought up a good point, but overall the strength will be almost equivalent between the two concepts. Similar to some aftermarket racing car rims, dirt bike rims, and other high-end racing concepts, the webbing will typically sweep back in the order of the T700 upside down (as the main gear case upgrade is using). I've been testing the T700 design on multiple setups (8S, 10S, and 12S) and have never stripped a gear, so the strength is more than adequate with the gear upside down (which shows off the aesthetics of the KDE Direct upgrade also
#10 | |
Thanks My 2 Cents |
#11 |
Hi Guys,
I was wondering how the slightly different gear ratios may (or may not) effect the load on the motor and ultimately flight times using the following as set up examples: Scorpion 4025-630 on 12s aiming for approx 2100 with 600 mains. 600 main gear 170t with 15t pinion 700 main gear 164t with 14t pinion Duke
T-REX 600ESP, 12S, SCORPION 4025-630, JIVE 80HV, JR8717, BEAST-X, EDGE FBL LE-603, LE - 95, OUTRAGE LIPO. T-REX450 PRO, 6s. T-REX250, HK2206 - 3900. SCORPION 25A ESC V2, OUTRAGE LIPO. |
#12 | |
Not one of us is as smart or knowledgeable as all of us bonding together. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Brett |
#13 |
Hey Brett,
You may have the KDE Direct brand confused with another company, as this is the first hub I've released for the TREX 600E. I always found the stock Align hub to work great for the standard 600E gear set, so this is why I researched into allowing use of the stronger, taller gear set of the 700 for high-voltage, high-power setups on the 600E.
#14 |
Szia !
I think good ? The ideal setup with 12S Scorpion 630kv setup ? T 700 main gear 164T KDE main gear case 14T Pinion The original 600 E main gear very fast broken Thank's by
Pilot Peter Martin To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. My Galery: To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#15 |
150 Combined flights on 2 700gear upgrade hubs and they are working like a champ.
Thanks Keg |
#16 |
did any of you guys have problems after install?
i have the hub ,havent run it yet as it is like warped . the gear meshes but goes up and down when moving around as normally would , any ideas .. thanks in advance guys |
#17 |
is like a warped gear so put new one in and still same so i am thinking hub or bearing , all new bird .. esp 600 put normal gear set in is fine and ran straight as should when head turned ...
#18 |
Location: Born in London, Live in ATL, Heritage from Ghana
Are you able to do this for the 600N, I think you have one for the 700N
![]() Thanks Robert
------------------------------------------------------------------------------ <<< Ashlyn, daddy loves you more than his heli's, don't mind mummy >>> <<< ..............MA Spectra G (Supporting Made in USA), DX7.............. >>> ------------------------------------------------------------------------------ |
#19 |
I have been using the hub for some time now, but not with the align 700 main gear. The align 700 gear stripped very easy, i would say easier then running the 600 main gear. I ended up using the Microheli .7 cnc main gear. Which is the only main gear, that can stand all the abuse i can throw at it. I have been trying to strip it in flight, and i have not been able to, no matter how hard i try, unlike the align 700 main gear that i can strip very easy. Funny thing is that most of the stock 700 main gears i stripped in a way i have never seen before. It striped in sections. The first 1/6th of the gear would be stripped the next 1/6th will be fine, followed by the next 1/6th was stripped again and so on. Like if the gear was flexing. I think ideally i would like a CNC gear like the one microheli makes for the 700, but for the 600. I would say around 11mm tall, which is the height of my modified Microheli 700 CNC gear.
heres a short video of the align 700 main gear,and how easy i can strip it. |
#20 |
I never managed to strip a gear on my T600E (or my other team pilots) with the upgrade installed, so this is the first I've seen of this happening. I've been doing a lot of research on the gearing stripping issues (I personally have been flying a T700E 12S setup and had been stripping the stock T700N gears left and right) and my team and I have found great solutions to stop this from occurring for most setups. The Align T700N gear is surprisingly very strong when the pinion is fully supported, as it seems it's the flex at the motor pinion due to the high-bending forces that is causing the problems. Just a flex of +0.010" is enough to strip the gear, so the best two options we've found are:
1. Make sure your gear mesh is PERFECT - meaning, almost zero play between the pinion and the main gear. It comes down to feel and practice, but this is the most critical part. 2. It's worth installing a counterbearing if you are running 12S setups and the one I've been using is the Mikado 6mm counterbearing (MIK 4148) which works excellent (ReadyHeli and other vendors carry it). This prevents the bending loads from flexing the shaft and is easily installed (although it took a bit of rework to make it fit no my T700E). Since I've been using these two items, I haven't stripped a gear on my T700E and that's with over 7 hp peaks in power! I'm running the same motor as you (NEU 1915H/1.5Y) and I haven't had a problem since using the counterbearing.
