Go Back   HeliFreak > R/C Helicopter Support > E-Sky Helicopters > King II/III/IV and CP 2/3
King II/III/IV and CP 2/3 E-Sky King 2, 3, 4 plus CP 2 & 3
Old 04-25-2009, 03:45 PM   #1
dawin2122
Default How i put a two 3s lipo packs in series
hi guys i need to know the combinatin to convert two 3s lipo batteries in one 6s lipo battery to use in one heli can use 6s battery thanks guys
dawin2122 is offline        Reply With Quote
Old 04-25-2009, 04:08 PM   #2
Mike66
You can use the Y-cable you have to series charge the two 3S packs. Discharging works the same as charging, just in reverse
Make sure your 6S heli does not kill your two 3S packs by trying to over-discharge them.
T-Rex 500
Mike66 is offline        Reply With Quote
Old 04-25-2009, 04:24 PM   #3
dawin2122
and did not got any special combination? just use the y cable can i use to charge two at the same time in the charger and that set no need to put any fancy? thanks mike for your great help everytime
Old 04-25-2009, 05:15 PM   #4
Mike66
When you are discharging the pair of packs, the only connections are through the discharge leads, so order does not matter. The way the Y-cable is made, you cannot connect the batteries incorrectly.
When you are balance charging, you are using the discharge leads and the balance taps, so order is important. The Number 1 battery is the one that has its negative (black) lead connected directly to the charger. Its positive (red) lead is connected to the Number 2 battery negative lead.
Good luck, but be kind to your battery. If you try to overdischarge it, it could puff, or worse.
T-Rex 500
