| RCDN 500 Nitro Conversion R/C Depot Hobbies RCDN 500 Nitro Conversion Kit Support |
Guys, been trying to find my answer but have no luck.
Are the six magnets a must? If so, why? Thanks |
Use 6 magnets ONLY if you are using the Align RCE-G600. The RCE-G600 operates between 10500 and 21000 rpms and because we designed the RCDN500 with the magnets mounted onto the main gear and not to the fan, 6 magnets are needed for the RCE-G600 to work properly.
You must mount all six magnets, the side which the sensor reads, up. |
what if you use the atg can it run 1:1 like a multigov? i about got my 500 nitro built and am trying to decide on what gov to use
thanks gary |
I'm using a Throttle Jockey with 6 magnets. Works like a charm
If, at first, you don't succeed, then skydiving is probably a bad idea for you. |
Where do install the magnets i got two raptors and the magnets go on the fan but on this 500 i don,t know. need help.
#6 |
After much testing, we found that using 6 magnets mounted to the main gear do not provide for consistent RPM. We suggest that you use the Spektrum sensor from the AR7100r to govern the RPM.
Please see these posts: http://video.helifreak.com/?subpath=...e=aligngov.wmv http://www.helifreak.com/showthread.php?t=138234 These are the parts to use: http://www.flyhelirus.com/servlet/th...-Remote/Detail http://www.flyhelirus.com/servlet/th...ate-for/Detail http://www.flyhelirus.com/servlet/th...Bracket/Detail http://www.flyhelirus.com/servlet/th...sor-%26/Detail If you can only use the magnets, here is a picture of the magnets on the main gear |
#7 |
Thank you.
