Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite)
Blade Helicopters (eFlite) Blade Helicopters (eFlite) CP, CX, mCX CX II, CX III. and others
Old 04-28-2009, 01:15 PM   #1
dabigrussian
Default you wouldnt believe it....
hey all,
thanks for all the advice recently with my upgrade! to get the tail esc to arm, i have to - ready for this - (disconnect tail esc from gryo 1st) plug in main esc to battery, let gyro arm,then plug in tail esc to soldered wires off the battery to seperately power it! let tail light come on then plug tail esc into gyro, then hold left stick and voila! she spins her tail!!!
now the horizon hobby guy thought i was nuts putting in all the electronics and motor from a b400 into the cppro. like 600 horsepower in a civic he said. should i drop my throttle and pitch curves from what i use with the b400?
for the tail, trim seems to increas and decrease speed much more than change directions! in the gyro menu, ive gone from 35% to 80%. none seem to hold the tail smooth! oh, and its now a single tail until i get a new 2nd tail- it started to smoke!
any dx6i settings with a brushless motor that works for a beginner doin hoverin and basic ff?
thanks all
rc heli
dabigrussian is offline        Reply With Quote
Old 04-28-2009, 05:47 PM   #2
WickedDragon
Hey.... is the positive wire to the tail esc disconnected at the gyro? If not, slide it out of the connector and try it again without the rewiring on the pad!
Doug Bonham, WickedDragonRC
Gravity isn't just a good idea, it's the LAW!
TRex450SE DFC; TRex450Pro DFC; TRex500 DFC Pro; TRex600N DFC's; CHP-TRex600eDL DFC; Trex700e DFC Pro
WickedDragon is offline        Reply With Quote
Old 04-29-2009, 08:48 PM   #3
habendanio
What the best way to change the tail motor in a cp pro2 to use a brushless tail motor?
Do I need to use a different gyro, BL ESC, mixer ?
habendanio is offline        Reply With Quote
Old 04-29-2009, 09:06 PM   #4
JohnM
Why do you want to go with a brushless tail? The stock tail setup (compared to the previous versions of the Blade CP) works great.
John
JohnM is offline        Reply With Quote
Old 04-30-2009, 08:59 AM   #5
WickedDragon
The optimum setup currently is
Medusa Research 12mm Afterburner 4000Kv
(Just looked.... came WAY down in price $29.99.... awesome motor)
CC Phoenix 10 or Thunderbird 9 Brushless ESC
GWS 3020 Tail Rotor or stock CPP2
No mixer, same gyro is fine. Better gyros make a big difference though.
John
The CPP2 tail would work well because the brushed upgrade to it's predecessors worked well. However, All brushed motors burn out! Brushless motors, although initially more expensive to install, provide virtually maintenance free use and extremely long life.
With the money I've spent in stock and Brushed DD tail motors at $10 a pop, I could have gone brushless initially for about the same money. So if you're going to hop up a BladeCPxx and willing to spend the money up front, it's quite prudent to use the most effective setup.... wouldn't you agree?
Old 04-30-2009, 09:48 AM   #6
dabigrussian
+1 for above! he's right! if i wasnt blowing up my 3in1's i would leave it stock, yet my stock cp pro is crap compared to your cp pro 2! i have added the gyro you have and a whole lot more- just to fly nice. yours is a big step up from the cp pro.
for brushless tail- you can read a bunch of other threads here about the upgrade. good luck
rc heli
Old 04-30-2009, 03:47 PM   #7
JohnM
I have gone the brushless route in the past and could never seem to get it working as well as the stock tail works on the pro 2. The stock 2in1 and gyro setup seems to just work well together. Since I am using the stock pro 2 TX, I wouldn't even attempt to go with a brushless tail. You really need a computerized TX to tweak the brushless tail setup. I also believe, in general, brushed motors seem to start faster (better) than brushless motors and that is very important for a motorized tail.
John
Old 04-30-2009, 03:59 PM   #8
JohnM
I will agree with you that the brushless setup will generally be less expensive in the long run, however I have ruined some brushless tail motors in the past in crashes. The 3 wires off the back of the motor can are prone to getting damaged. It is best to cover them in Goop or the liquid electrial repair stuff.
John
Old 05-01-2009, 11:02 AM   #9
WickedDragon
The wire on the 12mm motors are fragile and are actually the wire from the coils. You have to be careful. I will either heat shrink them or spiral wrap and heat shrink them if I feel the need to do so..... lot easier to remove. I'm a really, really big fan of cable management! HATE messy wiring and placement! The less you see the better!
Old 05-01-2009, 11:57 AM   #10
JohnM
Yes, they are the motor windings, hence if they get pulled out during a crash and a tail boom strike, the motor is rendered unusable....
John
Old 05-01-2009, 02:37 PM   #11
dabigrussian
thats pretty sh%^&tty that a brushless could be that fragile.
rc heli
Old 05-01-2009, 02:50 PM   #12
JohnM
It's the price we pay for demanding these tiny low weight motors. Check out the motors being used on the Walkera sub micros and that Ammo motor will seem like it is built like a tank
Old 05-02-2009, 01:09 PM   #13
WickedDragon
For real.... servo motors for mains! Not to mention the wiring... light gauge varnish insulated armature wire.
Slide a piece of 1/8" fuel line over the motor wires and heat shrink it....you'll be fine.... just be gentle!
