Go Back   HeliFreak > R/C Helicopter Support > Avant RC - Mostro & Aurora
Avant RC - Mostro & Aurora Avant Mostro, Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support
Old 06-23-2006, 04:43 PM   #1
Eric Brandenburg
Default Avant clutch Bell play
Hi guys, I have a few MM's of play in my avants clutch bell, is that normal, or is there something wrong on mine?
Give me a lever long enough and I'll move the world...
Eric Brandenburg is offline        Reply With Quote
Old 06-24-2006, 12:24 AM   #2
mevigavant
you mean up and down play? if so, you're probably missing the small o-ring and brass washer that go on the clutch shaft underneath the clutch bell.
mevigavant is offline        Reply With Quote
Old 06-24-2006, 06:33 AM   #3
Jafa
Yeah, I would assume you mean vertical play, washer and o-ring
When new the bell to clutch shoe fitting should be 0.4mm gap
so lateral play of the bell should not be that much
(and when the clutch shoes bites the bell is locked up anyway)
Gryphon field rep
Jafa is offline        Reply With Quote
Old 06-24-2006, 07:42 PM   #4
Eric Brandenburg
Ok thanks guys, what does the assembly look like with the oring and washer on it, I got mine used.
Old 06-25-2006, 12:33 AM   #5
mevigavant
It has an o-ring and brass washer on the clutch shaft. If you go to augustoheli.com and go to the parts page you will see it in the x-spec or freya manual.
Old 06-25-2006, 10:21 AM   #6
Eric Brandenburg
Ok thanks guys, this forum is awesome. :glasses2:
