Old 04-29-2009, 01:08 AM   #1
HeLiJerSey
Default hooking up 2 6cell batteries. how to hook up series or parallel?
i wanna run 12 cell do i hook the 2 lipos in series or parallel. i have to buy the harness thats already made. so do i get a series or parallel?
thanks guys
HeLiJerSey is offline        Reply With Quote
Old 04-29-2009, 01:20 AM   #2
Mike66
thanks guys
For 12S, you want to connect the two 6S packs in series. If you are using Deans Ultra connectors on your packs, this is the type of series cable you will need. For any other connector, follow the same pattern for the Deans wiring and you will be fine.
T-Rex 500
Mike66 is offline        Reply With Quote
