Old 04-30-2009, 08:15 PM   #1
T-ster
Default 12C LiPo - OK?
I bought a couple of 2000 mah Kong Power batteries a few days ago and they just arrived. I didn't realize until I looked closer at the package that they are 12C batteries. I assume for a nitro bird that's ok, but wanted to verify. Ok or not?
Thanks.
T-ster is offline        Reply With Quote
Old 04-30-2009, 08:33 PM   #2
TheBum
Yes, they should be fine. Let us know how they do; I'll be in the market for some new RX packs.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is online now        Reply With Quote
Old 05-01-2009, 05:02 AM   #3
helihathnofury
I bought the Outrage XPRX. Seems to do a good job and a nice shape too!!!!!!
http://www.fast-lad.co.uk/store/outr...er-p-5763.html
Not cheap though at 23 or $33.
Skip
Happy Heli-days !!!!!!!! Skip
T-Rex 450Sport, T-Rex 500ESP,
T-Rex 600NSP FBL, OS55, MicroBeastX Plus,
Futaba 14SG,
helihathnofury is offline        Reply With Quote
Old 05-01-2009, 07:58 AM   #4
MaSt0RaS
i have the outrage 3600 its great bat for over 8 flights!
MaSt0RaS is offline        Reply With Quote
Old 05-01-2009, 08:35 AM   #5
TheBum
Back to the original question, the electronics are not going to draw anywhere near the 24A maximum the battery is spec'ed at, so any more than 12C is overkill. I doubt the battery will even get warm. It's only when you get to the high current draws of an electric motor that C rating becomes significant.
HeliFreak Support
Old 05-02-2009, 08:19 AM   #6
T-ster
My unofficial test on my 600N with an Align 2-in-1 at home revealed what I was anticipated.
The battery I was growing concerned was a 1-1/2 yr old Kokam 2000 mah LiPo. Lately it always has been dropping one light on the Align 2-in-1 once I press the glow ignitor. It will go down a 2nd light on the 2nd flight typically with the glow ignitor energized. One light will come back on after it kicks off, but still I would be down 2 lights after 2 flights. Also, all the lights slightly dim when I hit the ignitor.
Tried the Kong Power 2000 mah and it seemed to light the Align 2-in-1 lights brighter and when I hit the glow ignitor 3 times in a row, the light all stayed bright.
I think the Kokam was starting to get "tired".
With my new battery and a new spiffy canopy, I'm ready to rumble once the weather cooperates.
Old 05-02-2009, 09:54 AM   #7
TheBum
Yeah, it's been pretty bad. But, it beats a drought like we've had in years past.
I think my packs are getting "tired" too because I see the same things you were seeing.
HeliFreak Support
Old 05-02-2009, 02:54 PM   #8
T-ster
Flew with the new LiPO and was tinkering with settings, but got at least 2 flights with all lights on. Much better than before.
Old 05-02-2009, 03:19 PM   #9
LjArpin
Default 11.1v
I know a 3/11.1v cell Lipo would weigh a bit more but could the Align 2n1 handle it? or will it only work with 7.4v
I guess what I'm Saying is does the 2n1 step down the power so that you could plug in any battery and it will convert it to what the receiver can handle?
I have a couple 3 cells laying around and I'm having some of the same problems, After a fresh charge i only got 4 flights and at the end there were only 2 solid lights with one green flickering!
Thanks for the Help!
Trex600, Blade 400 2.4ghz Jrx9303
::::::::::::::Real Heli::::::::::::::::
MH-53CE Power Plants Mech
LjArpin is offline        Reply With Quote
Old 05-02-2009, 03:57 PM   #10
rg686
From the product spec the 2-in-1 will only work with 2 cell LIPO
rg686 is offline        Reply With Quote
Old 05-02-2009, 04:11 PM   #11
LjArpin
Default Ohh Well
Ohh Well
I kinda though so but was hoping i didn't have to buy a battery!
I guess i'll try one of those Outrage XP's!
See if I can get at least 6-7 flights out of one charge......
Old 05-03-2009, 07:55 PM   #12
Penguin
I'm using one of these and I still have green lights after 7 flights.
B400 - 122/10 | T250 - 142/5 | T450 - 123/6 | T450 Pro - 67/2 | T600N - 52/0 | O550 86/0 | T700EC - 116/2 | T500 - 314/2 | L500 3D - 169/1 | L600 SE - 43/0
Penguin is offline        Reply With Quote
Old 05-03-2009, 08:08 PM   #13
Dirk_Pitt
I have been "eye-balling" that battery for a couple of months now...I want one but am concerned with the weight and size...Do you mount it under the electronics tray??? Do you have any pics???
Dirk_Pitt is offline        Reply With Quote
Old 05-04-2009, 09:51 AM   #14
Penguin
I mount it on top of the electronics tray. Will post a pic this evening.
Old 05-04-2009, 08:14 PM   #15
Penguin
The bat in the middle is a modified 3S 2200 that had once cell go bad:
Old 05-04-2009, 08:27 PM   #16
Dirk_Pitt
That 5000mah is SWEET...I have my reciever mounted on top of the tray though...Is there a chance that it would slip between the frames and hang under the tray???
Nice pics BTW...
Old 05-05-2009, 09:16 AM   #17
LjArpin
Red face Well Will it?
My Multi Gov pro is on top so no room up there!
I'd like to know if it would underneath as well:o....or will it?
Old 05-05-2009, 09:19 AM   #18
Penguin
I'll try it out this evening and post another pic.
Old 05-06-2009, 08:48 AM   #19
Penguin
I mounted the bat under the tray and it fit between the the frame sides just fine and the canopy still mounted fine. I took a couple of pics but did not get them posted last night. If you want, I will post tonight.
Old 05-06-2009, 09:35 AM   #20
LjArpin
Default Awesome!
Thanks Penguin,
Im ordering mine when I get home!
Your help is very much appreciated!
