Old 05-03-2009, 09:48 PM   #1
kaz172
Default swash help
Can anyone explain or help what might be going on when I fly my 250. it is ok with hovering. But when i am in idle up and punch the throttle the heli leans to the left and when i punch full negative collective the heli leans a little to the right and so I put it in thottle hold and just went up and down in idle up and looked at the swash carefully and it just seemed the servos were not matching up all that well but I played with the travel at full up and down and did not fix the problem it is when I punch the controls to full collective from down to up that I notice the left side seemed a to hesatate a little around center stick. Is this a sign of a sloppy swash or do you think my servos are off for some reason I have crashed twice. Thanks any help would be great thanks.
kaz172 is offline        Reply With Quote
Old 05-03-2009, 10:35 PM   #2
mrivers
Sounds like your collective servo endpoints need to be adjusted (each one individually).
Mike.
mrivers is offline        Reply With Quote
Old 05-03-2009, 10:57 PM   #3
kaz172
I think that is what i have done with the travel adjustments so they are right at top middle and bottom but when i move the collective fast from top to bottom around center stick the swash leans a little, very minute but when doing fast idle up and punching the collective the heli seems to want to take off to the left. Maybe the ds410 are just not all that acurate. they just seem to move alittle at different times during fast stick movements.
Old 05-04-2009, 12:34 AM   #4
kyalamikid
Is it always the same servo that leans? Perhaps you have one faulty. Mine have been great, no leaning at all.
Logo 500SE, Gyrobot 900, Jive 80HV, BLS251, Scorpion 4025-1100
Trex 500, I2 FBL Head, JR3517's, Gyrobot 700, JR8900G, CC ICE75, Scorpion 3026-1400
Trex 250, Flybarless, Gyrobot 900, Innolab 201
kyalamikid is offline        Reply With Quote
Old 05-04-2009, 03:41 AM   #5
Aussie_phoenix
I had a similar problem. The elevator servo seemed slow to follow the others when going collective up and down. I noticed it when using a swash leveller, soon after my ESC cooked. Sure enough after some fault finding it turned out that the elev servo was overheating the ESC. Changed it out and all is now well.
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
Old 05-04-2009, 02:45 PM   #6
mrivers
Sounds like you front left servo is a little slow then. Check for binding (ball links, head mechanics, twisted servo case etc) or stripped gears.
Mike.
