| 250 Class Electric Helicopters 250 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
So i pulled the trigger on a 250 super combo.... What are the choice batteries to run? Also, what is everyone using for connectors on the battery? What parts should i upgrade to alum from the get go? OH yea.... what blade set up... not looking for 3d, more about stability...
thanks |
Theres another recent thread about batteries, ally bearing blocks and 205d carbon blades to start.
Cheers, Fixxxer |
I'm flying the TP Pro Lite V2 910 maH. And I'm using JST connectors. Congrats, you're gonna love it!
As far as upgrades go... well it's already blinged out. You probably won't need any. I did upgrade to CF mains not for any other reason other than I like CF and how they cut the wind.
RC Heli's are flying moneypits! |
what rear blades should i run?
I'm running the rounded ones. They do fine. I had a little tail wag but when I moved the control guide closer to the servo bending the tail servo rod slightly... all wag problems went away with the ds420 and I was able to set the gain in my Dx7 to something like 67%.
There is a lot of talk about how bad the tail is, but I haven't had any. I just tuned it and tried different things like above. I also set my Travel Adjust on the tail to like 140%. My piros are as fast as they are on my 450. Make sure you go to Ready Heli and get the Trueblood swash plate leveler. It's invaluable and you'll get your swash perfectly leveled.
#6 |
The CF blades improve collective control giving it a crisper feel & yep JST connectors same as on the ESC. Tail blades iv'e cut down to 34mm but now i have it totally sorted im sure the stock length will be fine.
Cheers, Fixxxer |
