Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 05-09-2009, 09:55 PM   #1
pvande
Default Calibration of Zero Alpha - not the usual problem
I run the zero alpha gov on my raptor and have a problem with the calibration - but it is not the usual problem that everybody has.
I can get into calibration mode and have set the servo travel per the instructions. However it appears to only set one end of the servo travel (max) and not the lower limit.
When I power up the governor, the throttle servo jerks in an arc that travels further than the lower limit of where I've set the servo travel until it settles at idle - this causes the throttle servo to bind for appx. a quarter second when it tries to move the throttle arm further than the mechanical movement allows.
Any advice would be appreciated.
pvande is offline        Reply With Quote
Old 05-23-2009, 09:46 AM   #2
NitroAl
I gave up on mine and bought a CY ATG!
Same price-Far superier!
CustomHeliParts/KDE TRex 700N
ThunderTiger X50 FBL
Ely.Q Vision 90
Ely.Q Vision 50
NitroAl is offline        Reply With Quote
