Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 06-21-2004, 10:11 PM   #1
clark
Default SGL-01 Gyro
Hi,
I am new to this site and hope I can find some good tips and give some tips.
I recently purchased 5 new 94322 servos and the SGL-01 gyro.
I am wondering if anybody has any tips for setting this system up. I am having trouble getting the tail rotor to function properly through the gyro.
I have the RD6000 radio.
If anyone can shut me some pointers that will be greatly appreciated and hope I can return some pointers too.
Thanks,
Clark
Flying airplanes is a good way to travel but bad way to land.
clark is offline        Reply With Quote
Old 06-25-2004, 07:48 AM   #2
OC Bob
What is the problem with your gyro? Is the tail staying to one side when you give it a rudder command, while testing it on the work bench? Or floating to one side on its own.
This is normal behavior for a heading hold gyro system, if this is what you are experiencing.
Also servo speed, and tail rotor servo arm length are important to make the gyro do it's job correctly while flying.
Send me a P.M. explaining what trouble you are experiencing, with a little detail concerning the issue. I'll do my best to help you out if I can.
OC Bob
OC Bob is offline        Reply With Quote
