Belt CP E-Sky Belt CP
Old 05-21-2009, 10:11 PM   #1
don99
Default Copterx v2 metal collar (cx450-01-22)
I removed the old Copterx v2 feathering shaft to replace a new one. Somehow, I forgot to note which way the metal collar (CX450-01-22) (that lies between the O-rings and the blade grip) should be fit into. I look at the Copterx v2 manual, the metal collar look different so i can not use it for reference. I need help. Thanks. Don
don99 is offline        Reply With Quote
Old 05-21-2009, 10:39 PM   #2
luisg877
Hello
i don't know muh about copter x products, but if it has a lip side and a flat side, the flat side faces the o-ring, and the lip side faces the bearing. hope this helped and you can assemble your heli
luisg877 is offline        Reply With Quote
Old 05-21-2009, 10:57 PM   #3
don99
Originally Posted by luisg877 View Post
Hello
Thank you luisg877.
Old 05-22-2009, 09:53 AM   #4
B2TheEYo
luisg877 is right. =)
B2TheEYo is offline        Reply With Quote
